2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:fix_zero_size_arrays into epics-base:7.0
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: mp+386175 at code.launchpad.net
Date: Tue, 23 Jun 2020 07:05:14 -0000
Yes, 'dbpf some:pv 1 2 3 4' would look more natural. For VxWorks this would be limited to 9 array elements though. RTEMS? Let's see what I can do.
field (INP, "empty:array CP") does not give the desired result yet. I am still working on that. Maybe it will change the output of 'caget partially_filled:array" though (which would them become compatible with camonitor partially_filled:array). As I said, still working on it ...
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/386175
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:fix_zero_size_arrays into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:fix_zero_size_arrays into epics-base:7.0 mdavidsaver via Core-talk
Next: Build failed: EPICS Base 7 base-7.0-39 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Next: Re: [Merge] ~dirk.zimoch/epics-base:fix_zero_size_arrays into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 26 Jun 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
