2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:fix_zero_size_arrays into epics-base:7.0
From: mdavidsaver via Core-talk <core-talk at aps.anl.gov>
To: mp+386175 at code.launchpad.net
Date: Tue, 23 Jun 2020 04:07:58 -0000
Review: Approve
Looks good.
wrt. dbpf.  So this would look like:
> dbpf "some:pv" "1 2 3 4"
Did you consider switching dbpf() to use iocshArgArgv to capture the value element(s)?
This doesn't have to be the only argument.  This seems more natural to me, and potentially
avoids some of the added string parsing code.  I suppose this would be a disadvantage for
vxworks though?
Also, an example of this should be added to the help message for dbpf.
This is in dbIocRegister.c.  I can do this after merge if needed.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/386175
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:fix_zero_size_arrays into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Jenkins build is back to normal : epics-pvData-mac #187 APS Jenkins via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:fix_zero_size_arrays into epics-base:7.0 Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: [Merge] ~dirk.zimoch/epics-base:fix_zero_size_arrays into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 23 Jun 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
