2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Problems with dbLinkIsConstant
From: Torsten Bögershausen via Core-talk <core-talk at aps.anl.gov>
To: <core-talk at aps.anl.gov>
Date: Tue, 30 Jun 2020 10:09:01 +0200
Hej all,
I have a problem with dbLinkIsConstant(), it seems.
If I run the motor module with this code:
#if LT_EPICSBASE(7,0,0,0)
#define dbLinkIsConstant(lnk) ((lnk)->type == CONSTANT)
#else
#include "dbLink.h"
#endif
And later
    if (dbLinkIsConstant(&pmr->dol))
        pmr->udf = FALSE;
Debug(pmr,3, "init_record %s\n", "dbLinkIsConstant=true set UDF=FALSE");
        recGblInitConstantLink(&pmr->dol, DBF_DOUBLE, &pmr->val);
I get this log message:
[motorRecord.cc:906 IOC:m1] init_record dbLinkIsConstant=true set UDF=FALSE
However, the .DOL field is empty.
Is this the expected behavior ?
EPICS base is here:
commit 34834dfe973a577f342503441e7b33b7fe322de5 (HEAD, tag: R7.0.3.1, base-R7.0.4)
Author: Andrew Johnson <anj at anl.gov>
Date:   Fri Nov 1 14:08:44 2019 -0500
Thanks for any help
/Torsten
Re: Problems with dbLinkIsConstant Johnson, Andrew N. via Core-talk
Prev: Build failed: epics-base base-integration-573 AppVeyor via Core-talk
Next: Build failed: EPICS Base 7 base-7.0-43 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: Problems with dbLinkIsConstant Johnson, Andrew N. via Core-talk
ANJ, 30 Jun 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
