2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: version headers
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: "Zimoch Dirk (PSI)" <dirk.zimoch at psi.ch>, "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Tue, 30 Jun 2020 08:46:35 -0700
Hi Dirk,
Have a look at genVersionHeader.pl which is installed by Base since 3.15.0.1.
used here
https://github.com/epics-base/epics-base/blob/4c192e7bba7d3ff13e3a076d0082d55e4d807fac/modules/database/src/ioc/Makefile#L48
and by the example template
https://github.com/epics-base/epics-base/blob/d77a96d23d962f996f12e29255aa29beed64c1b1/modules/database/src/template/top/exampleApp/src/Makefile#L35
On 6/30/20 7:26 AM, Zimoch Dirk (PSI) via Core-talk wrote:
> Hi folks,
> I have a technical git related question. For StreamDevice, I used to update a version header file manually, but I always
> forgot to update the numbers when tagging a release. How can I do this automatically? Git has hooks, but none for tag as
> it seems (which would be also too late to be included in the tagged commit).
> The internet says: "No problem, simply generate the header (e.g. from 'git describe') when building your code." No
> problem indeed as long as I have the git repo. But those users that download zip files from github instead of cloning
> the repo complain now, as 'git describe' does not work for them, of course.
> Is there a way to generate the version header (or any other file that contains the related tag) on github when pushing
> the release, so it is included when downloading a release zip file?
> Dirk
version headers Zimoch Dirk (PSI) via Core-talk
Prev: Re: version headers J. Lewis Muir via Core-talk
Next: Re: Problems with dbLinkIsConstant Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: version headers Michael Davidsaver via Core-talk
ANJ, 30 Jun 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
