Found it. For the record:
I was using the epicsOldString typedef (deprecated, I know) as a convenient way to have a fixed size string type. Inside a function with an argument defined as epicsOldString *text , I did the "make sure it is null terminated" write as *text[MAX_STRING_SIZE-1] = '\0'; instead of (*text)[MAX_STRING_SIZE-1] = '\0'; Just rarely, depending on heap memory layout, the '\0' hit specific places in areas of memory with record instances, the structures were corrupted in a way that segfaulted the IOC. Note to myself: Array typedefs are EVIL. Thanks for all the hints! ~Ralph
| ANJ, 11 Jul 2020 |
Home
News
About
Talk
Base
Modules
Extensions
