But it was clearly an error in the Makefile. I need to be convinced that a proper Makefile would have this problem.
Sent from my iPhone
> On Jul 16, 2020, at 8:47 AM, Zimoch Dirk (PSI) <dirk.zimoch at psi.ch> wrote:
> Mi Mark
> Potentially there are other drivers than asyn which may run into the same problem.
> I think fixing it once and for all in base may be easier.
> Dirk
>> -----Ursprüngliche Nachricht-----
>> Von: Mark Rivers <rivers at cars.uchicago.edu>
>> Gesendet: Donnerstag, 16. Juli 2020 14:15
>> An: Zimoch Dirk (PSI) <dirk.zimoch at psi.ch>
>> Cc: core-talk at aps.anl.gov
>> Betreff: Re: EPICS linker problem
>> Hi Dirk,
>> I believe I have already fixed the problem you are seeing. It was an error in the
>> Makefile. It should have been linking with EPICS_BASE_IOC_LIBS, unless
>> EPICS_LIBCOM_ONLY was YES. This is the diff of the master branch from R4-39
>> for the Makefile.
>> corvette:asyn/asynPortDriver/unittest>git diff R4-39 Makefile
>> diff --git a/asyn/asynPortDriver/unittest/Makefile
>> b/asyn/asynPortDriver/unittest/Makefile
>> index 7618c68..a8a257f 100644
>> --- a/asyn/asynPortDriver/unittest/Makefile
>> +++ b/asyn/asynPortDriver/unittest/Makefile
>> @@ -10,8 +10,17 @@ TOP=../../..
>> include $(TOP)/configure/CONFIG
>> +USR_CFLAGS += -DUSE_TYPED_RSET -DUSE_TYPED_DSET -
>> DUSE_TYPED_DRVET
>> +USR_CXXFLAGS += -DUSE_TYPED_RSET -DUSE_TYPED_DSET -
>> DUSE_TYPED_DRVET
>> PROD_LIBS += asyn
>> -PROD_LIBS += Com
>> +ifeq ($(EPICS_LIBCOM_ONLY),YES)
>> + PROD_LIBS += Com
>> + USR_CXXFLAGS += -DEPICS_LIBCOM_ONLY
>> + USR_CFLAGS += -DEPICS_LIBCOM_ONLY
>> +else
>> + PROD_LIBS += $(EPICS_BASE_IOC_LIBS)
>> +endif
>> #Tests for the parameters
>> #TESTPROD_HOST += ParamValTest
>> Mark
>> ________________________________
>> From: Core-talk <core-talk-bounces at aps.anl.gov> on behalf of Zimoch Dirk
>> (PSI) via Core-talk <core-talk at aps.anl.gov>
>> Sent: Thursday, July 16, 2020 4:51 AM
>> To: 'core-talk at aps.anl.gov'
>> Subject: EPICS linker problem
>> Hello folks,
>> Today I found that some Linux (cross) architectures (using gcc 4.4.2, 4.7.2)
>> require an additional linker flag: -Wl,-rpath-link in addition to -L and -Wl,-rpath. I
>> noticed when compiling asyn.
>> It worked for me to change in
>> <BASE>/configure/os/CONFIG.Common.linuxCommon
>> PRODDIR_RPATH_LDFLAGS_YES = $(PROD_DEPLIB_DIRS:%=-Wl,-rpath,%)
>> to
>> $(PROD_DEPLIB_DIRS:%=-Wl,-rpath-link,%)
>> (Maybe the same should be done for SHRLIBDIR_RPATH_LDFLAGS_YES.)
>> Why this? Some linkers do not use -L for indirectly linked libs. E.g. libA.so
>> depends on libB.so and the program is linked with -lA but not with -lB, then some
>> linkers require that B is found in -rpath-link and do not consider -L or -rpath for
>> it. (Maybe the other linkers where it works do not even care about B?)
>> In asyn this is the case for test code which links with -lasyn -lCom only. But
>> libasyn.so had been linked with -ldbRecStd -ldbCore -lca -lCom and the linker
>> refuses to use those other libraries from -L<EPICS_BASE_LIBDIR> or -Wl,-
>> rpath<EPICS_BASE_LIBDIR>.
>> /opt/eldk-5.3/powerpc-4xx/sysroots/i686-eldk-linux/usr/bin/ppc440e-
>> linux/powerpc-linux-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -m32 -
>> mcpu=440fp -mhard-float --sysroot=/opt/eldk-5.3/powerpc-
>> 4xx/sysroots/ppc440e-linux -DUNIX -Dlinux -fno-strict-aliasing -O3 -g -g -
>> Wall -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -
>> I../../../../include/os/Linux -I../../../../include -I/usr/local/epics/base-
>> 7.0.4.1/include/compiler/gcc -I/usr/local/epics/base-7.0.4.1/include/os/Linux -
>> I/usr/local/epics/base-7.0.4.1/include -c ../asynPortDriverTest.cpp
>> linux/powerpc-linux-g++ -o asynPortDriverTest -
>> L/afs/psi.ch/group/8211/dirk/git/DRV/asyn/lib/eldk53-ppc4xxFP -
>> L/usr/local/epics/base-7.0.4.1/lib/eldk53-ppc4xxFP -Wl,-
>> rpath,/afs/psi.ch/group/8211/dirk/git/DRV/asyn/lib/eldk53-ppc4xxFP -Wl,-
>> rpath,/usr/local/epics/base-7.0.4.1/lib/eldk53-ppc4xxFP --sysroot=/opt/eldk-
>> 5.3/powerpc-4xx/sysroots/ppc440e-linux -rdynamic asynPortDriverTest.o
>> -lasyn -lCom
>> /net/gfa-fs-4/export/cross_tools/eldk-5.3/powerpc-4xx/sysroots/i686-eldk-
>> linux/usr/bin/ppc440e-linux/../../libexec/ppc440e-linux/gcc/powerpc-
>> linux/4.7.2/ld: warning: libdbRecStd.so, needed by
>> /afs/psi.ch/group/8211/dirk/git/DRV/asyn/lib/eldk53-ppc4xxFP/libasyn.so, not
>> found (try using -rpath or -rpath-link)
>> linux/4.7.2/ld: warning: libdbCore.so, needed by
>> linux/4.7.2/ld: warning: libca.so, needed by
>> /afs/psi.ch/group/8211/dirk/git/DRV/asyn/lib/eldk53-ppc4xxFP/libasyn.so:
>> undefined reference to `scanIoRequest'
>> [... more undefined reference errors...]
>> Even though the warning suggests using -rpath or -rpath-link, only -rpath-link
>> actually does the job.
>> Is there any (old) Linux architecture where adding -rpath-link may cause
>> problems?
>> Dirk
- EPICS linker problem Zimoch Dirk (PSI) via Core-talk
- Re: EPICS linker problem Mark Rivers via Core-talk
- AW: EPICS linker problem Zimoch Dirk (PSI) via Core-talk
Re: EPICS linker problem Michael Davidsaver via Core-talk
<2020>
2025
2026
<2020>
2025
2026
