2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1699445] Re: Link initialization from hex constants is broken
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Mon, 20 Jul 2020 00:56:35 -0000
Fixing the hex array issues in the fix for lp: #171445
** Changed in: epics-base/3.15
       Status: Fix Committed => Fix Released
** Changed in: epics-base/3.16
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1699445
Title:
Status in EPICS Base:
  Fix Released
Status in EPICS Base 3.15 series:
  Fix Released
Status in EPICS Base 3.16 series:
  Fix Released
Status in EPICS Base 7.0 series:
  Fix Released
Bug description:
  From Andrew Starrit <andrew.starritt AT synchrotron.org.au>:
  I recently upgraded many of my IOCs from base R3.14.12.5 to R3.15.5.  I have noticed a
  difference regarding literal hexadecimal numbers in INP fields as illustrated by the
  following example (the transition was otherwise painless):
  record (ai, "AI:HEX") {
      field (SCAN, ".1 second")
      field (INP,  "0x0200")
  record (longin, "LI:HEX") {
  record (aSub, "AS:HEX") {
      field (INPA, "0x0200")
      field (FTA,  "LONG")
      field (INPB, "0x0200")
      field (FTB,  "DOUBLE")
  For EPICS R3.14.12.5 I get:
  $ caget  AI:HEX  LI:HEX  AS:HEX.A  AS:HEX.B
  AI:HEX                         512
  LI:HEX                         512
  AS:HEX.A                       512
  AS:HEX.B                       512
  while for EPICS R3.15.5 I now get:
  AI:HEX                         512
  LI:HEX                         0
  AS:HEX.A                       0
  AS:HEX.B                       512
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1699445/+subscriptions
Prev: Re: AW: EPICS linker problem Mark Rivers via Core-talk
Next: Jenkins build is back to stable : epics-base-7.0-win64-test #199 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: [Bug 1887981] Re: json parser should accept hex numbers Andrew Johnson via Core-talk
Next: Build failed: EPICS Base 7 base-7.0-51 AppVeyor via Core-talk
ANJ, 21 Jul 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
