2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Jenkins test failures on macOS
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: EPICS core-talk <core-talk at aps.anl.gov>
Date: Mon, 3 Aug 2020 23:02:29 +0000
On Aug 3, 2020, at 4:36 PM, APS Jenkins via Core-talk <core-talk at aps.anl.gov> wrote:
So the change I committed earlier to Darwin's osdTimeGetCurrent() speeds it up significantly, but apparently at the expense of not giving nanosecond precision any more – I guess that’s probably not terribly surprising. All my wall-clock timestamps now have 000 in the nanoseconds part, although the monotonic clock isn’t affected as it uses a different kernel API.
The failures in the above Jenkins Mac build were these:
simmTest.tap ..............
not ok 136 - time stamp is recent
not ok 311 - time stamp is recent
not ok 435 - time stamp is recent
not ok 803 - time stamp is recent
not ok 996 - time stamp is recent
not ok 1171 - time stamp is recent
Failed 6/1176 subtests
	(42 TODO tests unexpectedly succeeded)
The problem is that in several places the test code is doing this:
testOk(epicsTimeLessThan(&now, mytime), "time stamp is recent");
which fails when now and *mytime are identical. I am changing that code to:
double diff = epicsTimeDiffInSeconds(mytime, &now);
testOk(diff >= 0.0, "time stamp is recent (%.9f sec)", diff);
Equality is now always allowed, and we get to see how different the timestamps actually are.
One of these (but not all) is inside a testTodoBegin("imprecise"); region.
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: Jenkins test failures on macOS Michael Davidsaver via Core-talk
Jenkins build became unstable: epics-7.0 » mac #245 APS Jenkins via Core-talk
Prev: Jenkins build became unstable: epics-7.0 » mac #245 APS Jenkins via Core-talk
Next: Re: Jenkins test failures on macOS Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 03 Aug 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
