I don't think that many people use \a (aka "bell") in a record field. I mean what to expect? That the computer rings the bell when the field is displayed? Thus I am fine with not supporting \a. (Or \e = 0x1b = ESC for that matter, which is a non-standard extension anyway).
The same for octal. Who would volutarily use octal?
What may be a bit surprizing is that the JSON5 specs require that \x
must be followed by exactly 2 hex digits, not by up to 2 digits, while C
happily accepts "\xf".
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1783475
Title:
const link support can't handle escaped charactors
Status in EPICS Base:
Triaged
Status in EPICS Base 3.16 series:
Won't Fix
Status in EPICS Base 7.0 series:
Triaged
Bug description:
I think the following should work, but it doesn't. The culprit seems
to be the call to dbTranslateEscape() in dbRecordField() and
dbRecordInfo(). The escaped newline is handled correctly by dbLex,
but the later dbJLinkParse() errors on the now unescaped newline.
> record(stringin, "test") {
> field(INP, {const:"multi\nline"})
> dbJLinkInit: lexical error: invalid character inside string.
> {"const":"multi line"}
> (right here) ------^
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1783475/+subscriptions
[Bug 1714455] Re: change request: filters should allow 'relaxed JSON' Andrew Johnson via Core-talk
Crash in EPICS 7 at iocInit Zimoch Dirk (PSI) via Core-talk
<2020>
2025
2026
[Bug 1783475] Re: const link support can't handle escaped charactors Andrew Johnson via Core-talk
[Bug 1783475] Re: const link support can't handle escaped charactors rivers via Core-talk
<2020>
2025
2026
