2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1783475] Re: const link support can't handle escaped charactors
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sun, 09 Aug 2020 05:47:33 -0000
PR for my json5 branch on GitHub at https://github.com/epics-base/epics-
base/pull/86
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1783475
Title:
Status in EPICS Base:
  Triaged
Status in EPICS Base 3.16 series:
  Won't Fix
Status in EPICS Base 7.0 series:
  Triaged
Bug description:
  I think the following should work, but it doesn't.  The culprit seems
  to be the call to dbTranslateEscape() in dbRecordField() and
  dbRecordInfo().  The escaped newline is handled correctly by dbLex,
  but the later dbJLinkParse() errors on the now unescaped newline.
  > record(stringin, "test") {
  >      field(INP, {const:"multi\nline"})
  > dbJLinkInit: lexical error: invalid character inside string.
  >                          {"const":"multi line"}
  >                      (right here) ------^
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1783475/+subscriptions
Prev: Build failed: EPICS Base 7 base-7.0-61 AppVeyor via Core-talk
Next: [Bug 1714455] Re: change request: filters should allow 'relaxed JSON' Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: [Bug 1783475] Re: const link support can't handle escaped charactors Andrew Johnson via Core-talk
Next: [Bug 1783475] Re: const link support can't handle escaped charactors Dirk Zimoch via Core-talk
ANJ, 10 Aug 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
