2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1783475] Re: const link support can't handle escaped charactors
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sun, 02 Aug 2020 06:12:54 -0000
I've changed my mind about octal escapes.
The JSON5 spec says "\012" should decode as a <nil> byte followed by
"12", whereas C and dbTranslateEscape() decode it as a line-feed
character "\n". We probably don't want to get different values for the
VAL and DESC fields as would happen here if we don't do something:
record(stringin, s1) {
  field(DESC, "\041")           # "!" - dbTranslateEscape()
  field(INP, {const:"\041"})    # "" - yajl
I now think the best solution is to drop support for octal character
escapes completely, and require strings to use \xXX hex escapes if they
can't use literal characters directly. I suspect octal escapes are very
rarely used now, and removing them would resolve this difference,
leaving just \a and \uXXXX to be decoded differently.
I will implement and document this change on my json5 branch.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1783475
Title:
Status in EPICS Base:
  Triaged
Status in EPICS Base 3.16 series:
  Won't Fix
Status in EPICS Base 7.0 series:
  Triaged
Bug description:
  I think the following should work, but it doesn't.  The culprit seems
  to be the call to dbTranslateEscape() in dbRecordField() and
  dbRecordInfo().  The escaped newline is handled correctly by dbLex,
  but the later dbJLinkParse() errors on the now unescaped newline.
  > record(stringin, "test") {
  >      field(INP, {const:"multi\nline"})
  > dbJLinkInit: lexical error: invalid character inside string.
  >                          {"const":"multi line"}
  >                      (right here) ------^
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1783475/+subscriptions
Prev: Build failed: EPICS Base 7 base-7.0-55 AppVeyor via Core-talk
Next: Jenkins build became unstable: epics-7.0 » linux32 #245 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: [Bug 1783475] Re: const link support can't handle escaped charactors Andrew Johnson via Core-talk
Next: [Bug 1783475] Re: const link support can't handle escaped charactors Andrew Johnson via Core-talk
ANJ, 09 Aug 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
