2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: Question from the RTEMS corner
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Chris Johns <chrisj at rtems.org>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Thu, 27 Aug 2020 03:31:34 +0000
Hi Chris,
On Aug 26, 2020, at 8:21 PM, Chris Johns via Core-talk <core-talk at aps.anl.gov> wrote:
Does the EPICS's build system support `make DESTDIR=/somewhere install`?
No, we don’t support a separate install step; our build system is unlike most others. You can configure EPICS Base and most other modules (before you start to build them) to install outside of their source tree by setting INSTALL_LOCATION, either on the make command-line or in the configure/CONFIG_SITE file.
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: Question from the RTEMS corner Michael Davidsaver via Core-talk
Question from the RTEMS corner Heinz Junkes via Core-talk
Re: Question from the RTEMS corner Ralph Lange via Core-talk
Re: Question from the RTEMS corner J. Lewis Muir via Core-talk
Re: Question from the RTEMS corner Chris Johns via Core-talk
Prev: Re: Question from the RTEMS corner Chris Johns via Core-talk
Next: Re: Question from the RTEMS corner Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 26 Aug 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
