2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: Question from the RTEMS corner
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: "Johnson, Andrew N." <anj at anl.gov>, Chris Johns <chrisj at rtems.org>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Wed, 26 Aug 2020 20:49:14 -0700
On 8/26/20 8:31 PM, Johnson, Andrew N. via Core-talk wrote:
> Hi Chris,
> On Aug 26, 2020, at 8:21 PM, Chris Johns via Core-talk <core-talk at aps.anl.gov <mailto:core-talk at aps.anl.gov>> wrote:
>> Does the EPICS's build system support `make DESTDIR=/somewhere install`?
> No, we don’t support a separate install step; our build system is unlike most others. You can configure EPICS Base and most other modules (before you start to build them) to install outside of their source tree by setting INSTALL_LOCATION, either on the make command-line or in the configure/CONFIG_SITE file.
With Base 7.0.4 INSTALL_LOCATION= can be combined with
> make LINKER_USE_RPATH=ORIGIN INSTALL_LOCATION=...
@Chris, if your tools complain about -rpath then use LINKER_USE_RPATH=NO
and FINAL_LOCATION= and set $LD_LIBRARY_PATH in the environment.
FINAL_LOCATION being a rough analog of 'configure --prefix=...' in
this context.  eg.
> export LD_LIBRARY_PATH==$PWD/lib/$EPICS_HOST_ARCH
> make LINKER_USE_RPATH=NO FINAL_LOCATION=/usr/local/epics INSTALL_LOCATION=/tmp/staging
Also maybe of interest to you:
https://github.com/mdavidsaver/epics-base/blob/spec/epics-base.spec
There is also Debian packaging.
https://github.com/epicsdeb/epics-base/blob/master/debian/rules
https://github.com/epicsdeb/epics-debhelper/blob/master/lib/Debian/Debhelper/Buildsystem/epicsmake.pm
Re: Question from the RTEMS corner Chris Johns via Core-talk
Question from the RTEMS corner Heinz Junkes via Core-talk
Re: Question from the RTEMS corner Ralph Lange via Core-talk
Re: Question from the RTEMS corner J. Lewis Muir via Core-talk
Re: Question from the RTEMS corner Johnson, Andrew N. via Core-talk
Prev: Re: Question from the RTEMS corner Johnson, Andrew N. via Core-talk
Next: Re: Question from the RTEMS corner Chris Johns via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 26 Aug 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
