2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: No access to epics-base.git for push
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: junkes <junkes at fhi-berlin.mpg.de>, core-talk at aps.anl.gov
Date: Fri, 28 Aug 2020 07:16:11 -0700
On 8/28/20 7:14 AM, junkes via Core-talk wrote:
> Apparently I have no right to upload my RTEMS5 stuff to epics-base.
> [h1@earth QtC-epics-base (7.0 *)]$ git push
> Username for 'https://github.com': hjunkes
> Password for 'https://hjunkes at github.com':
> remote: Permission to epics-base/epics-base.git denied to hjunkes.
> fatal: unable to access 'https://github.com/epics-base/epics-base.git/': The requested URL returned error: 403
> What is the best way for me to continue here now?
You should be able to push to https://github.com/hjunkes/epics-base
> heinz
> Changes to be committed:
>   (use "git reset HEAD <file>..." to unstage)
>         modified:   configure/CONFIG_COMMON
>         modified:   configure/os/CONFIG.Common.RTEMS
>         new file:   configure/os/CONFIG.Common.RTEMS-beagleboneblack
>         modified:   configure/os/CONFIG.Common.RTEMS-beatnik
>         modified:   configure/os/CONFIG.Common.RTEMS-pc386
>         new file:   configure/os/CONFIG.Common.RTEMS-qoriq_e500
>         new file:   configure/os/CONFIG.Common.RTEMS-xilinx_zynq_a9_qemu
>         new file:   configure/os/CONFIG.Common.RTEMS-xilinx_zynq_zedboard
>         modified:   configure/os/CONFIG.darwin-x86.Common
>         modified:   configure/os/CONFIG_SITE.Common.RTEMS
>         modified:   documentation/RELEASE_NOTES.md
>         modified:   modules/libcom/RTEMS/Makefile
>         modified:   modules/libcom/RTEMS/epicsMemFs.c
>         modified:   modules/libcom/RTEMS/epicsMemFs.h
>         new file:   modules/libcom/RTEMS/epicsNtp.c
>         new file:   modules/libcom/RTEMS/epicsNtp.h
>         modified:   modules/libcom/RTEMS/epicsRtemsInitHookPost.c
>         modified:   modules/libcom/RTEMS/epicsRtemsInitHookPre.c
>         modified:   modules/libcom/RTEMS/epicsRtemsInitHooks.h
>         new file:   modules/libcom/RTEMS/kernel/epicsRtemsInitHookPost.c
>         new file:   modules/libcom/RTEMS/kernel/epicsRtemsInitHookPre.c
>         new file:   modules/libcom/RTEMS/kernel/epicsRtemsInitHooks.h
>         renamed:    modules/libcom/RTEMS/rtems_config.c -> modules/libcom/RTEMS/kernel/rtems_config.c
>         renamed:    modules/libcom/RTEMS/rtems_init.c -> modules/libcom/RTEMS/kernel/rtems_init.c
>         renamed:    modules/libcom/RTEMS/rtems_netconfig.c -> modules/libcom/RTEMS/kernel/rtems_netconfig.c
>         new file:   modules/libcom/RTEMS/kernel/setBootConfigFromNVRAM.c
>         modified:   modules/libcom/RTEMS/ne2kpci.c
>         new file:   modules/libcom/RTEMS/posix/epicsRtemsInitHookPost.c
>         new file:   modules/libcom/RTEMS/posix/epicsRtemsInitHookPre.c
>         new file:   modules/libcom/RTEMS/posix/epicsRtemsInitHooks.h
>         new file:   modules/libcom/RTEMS/posix/libbsd_netconfig.c
>         new file:   modules/libcom/RTEMS/posix/libbsd_netconfig.h
>         new file:   modules/libcom/RTEMS/posix/rtems_config.c
>         new file:   modules/libcom/RTEMS/posix/rtems_init.c
>         new file:   modules/libcom/RTEMS/posix/setBootConfigFromNVRAM.c
>         modified:   modules/libcom/RTEMS/rtems_util.c
>         modified:   modules/libcom/RTEMS/setBootConfigFromNVRAM.c
>         renamed:    modules/libcom/src/osi/os/RTEMS/devLibVMEOSD.c -> modules/libcom/src/osi/os/RTEMS-kernel/devLibVMEOSD.c
>         renamed:    modules/libcom/src/osi/os/RTEMS/epicsAtomicOSD.cpp -> modules/libcom/src/osi/os/RTEMS-kernel/epicsAtomicOSD.cpp
>         renamed:    modules/libcom/src/osi/os/RTEMS/epicsAtomicOSD.h -> modules/libcom/src/osi/os/RTEMS-kernel/epicsAtomicOSD.h
>         renamed:    modules/libcom/src/osi/os/RTEMS/epicsMath.h -> modules/libcom/src/osi/os/RTEMS-kernel/epicsMath.h
>         renamed:    modules/libcom/src/osi/os/RTEMS/osdEnv.c -> modules/libcom/src/osi/os/RTEMS-kernel/osdEnv.c
>         renamed:    modules/libcom/src/osi/os/RTEMS/osdEvent.c -> modules/libcom/src/osi/os/RTEMS-kernel/osdEvent.c
>         renamed:    modules/libcom/src/osi/os/RTEMS/osdEvent.h -> modules/libcom/src/osi/os/RTEMS-kernel/osdEvent.h
>         renamed:    modules/libcom/src/osi/os/RTEMS/osdFindSymbol.c -> modules/libcom/src/osi/os/RTEMS-kernel/osdFindSymbol.c
>         new file:   modules/libcom/src/osi/os/RTEMS-kernel/osdMessageQueue.c
>         new file:   modules/libcom/src/osi/os/RTEMS-kernel/osdMessageQueue.h
>         renamed:    modules/libcom/src/osi/os/RTEMS/osdMutex.c -> modules/libcom/src/osi/os/RTEMS-kernel/osdMutex.c
>         renamed:    modules/libcom/src/osi/os/RTEMS/osdMutex.h -> modules/libcom/src/osi/os/RTEMS-kernel/osdMutex.h
>         renamed:    modules/libcom/src/osi/os/RTEMS/osdPoolStatus.c -> modules/libcom/src/osi/os/RTEMS-kernel/osdPoolStatus.c
>         renamed:    modules/libcom/src/osi/os/RTEMS/osdProcess.c -> modules/libcom/src/osi/os/RTEMS-kernel/osdProcess.c
>         renamed:    modules/libcom/src/osi/os/RTEMS/osdReadline.c -> modules/libcom/src/osi/os/RTEMS-kernel/osdReadline.c
>         new file:   modules/libcom/src/osi/os/RTEMS-kernel/osdSignal.cpp
>         renamed:    modules/libcom/src/osi/os/RTEMS/osdSock.h -> modules/libcom/src/osi/os/RTEMS-kernel/osdSock.h
>         renamed:    modules/libcom/src/osi/os/RTEMS/osdSpin.c -> modules/libcom/src/osi/os/RTEMS-kernel/osdSpin.c
>         renamed:    modules/libcom/src/osi/os/RTEMS/osdStrtod.h -> modules/libcom/src/osi/os/RTEMS-kernel/osdStrtod.h
>         renamed:    modules/libcom/src/osi/os/RTEMS/osdThread.c -> modules/libcom/src/osi/os/RTEMS-kernel/osdThread.c
>         renamed:    modules/libcom/src/osi/os/RTEMS/osdThread.h -> modules/libcom/src/osi/os/RTEMS-kernel/osdThread.h
>         renamed:    modules/libcom/src/osi/os/RTEMS/osdThreadExtra.c -> modules/libcom/src/osi/os/RTEMS-kernel/osdThreadExtra.c
>         renamed:    modules/libcom/src/osi/os/RTEMS/osdTime.cpp -> modules/libcom/src/osi/os/RTEMS-kernel/osdTime.cpp
>         renamed:    modules/libcom/src/osi/os/RTEMS/osdTime.h -> modules/libcom/src/osi/os/RTEMS-kernel/osdTime.h
>         renamed:    modules/libcom/src/osi/os/RTEMS/osiUnistd.h -> modules/libcom/src/osi/os/RTEMS-kernel/osiUnistd.h
>         new file:   modules/libcom/src/osi/os/RTEMS-posix/osdMessageQueue.c
>         new file:   modules/libcom/src/osi/os/RTEMS-posix/osdMessageQueue.h
>         new file:   modules/libcom/src/osi/os/RTEMS-posix/osdMutex.c
>         new file:   modules/libcom/src/osi/os/RTEMS-posix/osdPoolStatus.c
>         new file:   modules/libcom/src/osi/os/RTEMS-posix/osdSock.h
>         modified:   modules/libcom/src/osi/os/RTEMS/epicsMMIO.h
>         modified:   modules/libcom/src/osi/os/RTEMS/osdInterrupt.c
>         modified:   modules/libcom/src/osi/os/RTEMS/osdInterrupt.h
>         deleted:    modules/libcom/src/osi/os/RTEMS/osdSignal.cpp
>         modified:   modules/libcom/src/osi/os/RTEMS/osdVME.h
>         modified:   modules/libcom/src/osi/os/RTEMS/osiFileName.h
> [h1@earth QtC-epics-base (7.0 *+)]$ git commit
> [7.0 27e109de4] Porting to RTEMS5 with posix and libbsd
>  73 files changed, 3325 insertions(+), 380 deletions(-)
>  create mode 100644 configure/os/CONFIG.Common.RTEMS-beagleboneblack
>  create mode 100644 configure/os/CONFIG.Common.RTEMS-qoriq_e500
>  create mode 100644 configure/os/CONFIG.Common.RTEMS-xilinx_zynq_a9_qemu
>  create mode 100644 configure/os/CONFIG.Common.RTEMS-xilinx_zynq_zedboard
>  create mode 100644 modules/libcom/RTEMS/epicsNtp.c
>  create mode 100644 modules/libcom/RTEMS/epicsNtp.h
>  create mode 100644 modules/libcom/RTEMS/kernel/epicsRtemsInitHookPost.c
>  create mode 100644 modules/libcom/RTEMS/kernel/epicsRtemsInitHookPre.c
>  create mode 100644 modules/libcom/RTEMS/kernel/epicsRtemsInitHooks.h
>  rename modules/libcom/RTEMS/{ => kernel}/rtems_config.c (91%)
>  rename modules/libcom/RTEMS/{ => kernel}/rtems_init.c (93%)
>  rename modules/libcom/RTEMS/{ => kernel}/rtems_netconfig.c (97%)
>  create mode 100644 modules/libcom/RTEMS/kernel/setBootConfigFromNVRAM.c
>  create mode 100644 modules/libcom/RTEMS/posix/epicsRtemsInitHookPost.c
>  create mode 100644 modules/libcom/RTEMS/posix/epicsRtemsInitHookPre.c
>  create mode 100644 modules/libcom/RTEMS/posix/epicsRtemsInitHooks.h
>  create mode 100644 modules/libcom/RTEMS/posix/libbsd_netconfig.c
>  create mode 100644 modules/libcom/RTEMS/posix/libbsd_netconfig.h
>  create mode 100644 modules/libcom/RTEMS/posix/rtems_config.c
>  create mode 100644 modules/libcom/RTEMS/posix/rtems_init.c
>  create mode 100644 modules/libcom/RTEMS/posix/setBootConfigFromNVRAM.c
>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/devLibVMEOSD.c (93%)
>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/epicsAtomicOSD.cpp (100%)
>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/epicsAtomicOSD.h (92%)
>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/epicsMath.h (77%)
>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdEnv.c (79%)
>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdEvent.c (94%)
>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdEvent.h (68%)
>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdFindSymbol.c (72%)
>  create mode 100644 modules/libcom/src/osi/os/RTEMS-kernel/osdMessageQueue.c
>  create mode 100644 modules/libcom/src/osi/os/RTEMS-kernel/osdMessageQueue.h
>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdMutex.c (92%)
>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdMutex.h (68%)
>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdPoolStatus.c (79%)
>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdProcess.c (72%)
>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdReadline.c (98%)
>  create mode 100644 modules/libcom/src/osi/os/RTEMS-kernel/osdSignal.cpp
>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdSock.h (98%)
>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdSpin.c (98%)
>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdStrtod.h (64%)
>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdThread.c (80%)
>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdThread.h (58%)
>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdThreadExtra.c (75%)
>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdTime.cpp (99%)
>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdTime.h (96%)
>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osiUnistd.h (80%)
>  create mode 100644 modules/libcom/src/osi/os/RTEMS-posix/osdMessageQueue.c
>  create mode 100644 modules/libcom/src/osi/os/RTEMS-posix/osdMessageQueue.h
>  create mode 100644 modules/libcom/src/osi/os/RTEMS-posix/osdMutex.c
>  create mode 100644 modules/libcom/src/osi/os/RTEMS-posix/osdPoolStatus.c
>  create mode 100644 modules/libcom/src/osi/os/RTEMS-posix/osdSock.h
>  delete mode 100644 modules/libcom/src/osi/os/RTEMS/osdSignal.cpp
Re: No access to epics-base.git for push Johnson, Andrew N. via Core-talk
No access to epics-base.git for push junkes via Core-talk
Prev: No access to epics-base.git for push junkes via Core-talk
Next: Re: No access to epics-base.git for push Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 28 Aug 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
