2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: No access to epics-base.git for push
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>
Cc: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Fri, 28 Aug 2020 21:14:22 +0000
Hello Heinz,
The github epics-base repo is mirrored from the Launchpad repo, so nobody should be pushing commits to it anyway. There is an APS Jenkins job which does the mirroring, and it will either fail or discard any commits that someone pushes directly to GitHub.
Please continue to create pull-requests from your Github account as Michael suggested or merge requests from your Launchpad one, we don’t use the main GitHub repo for development branches.
- Andrew
Complicity is easy, Simplexity takes real work
> On Aug 28, 2020, at 9:17 AM, Michael Davidsaver via Core-talk <core-talk at aps.anl.gov> wrote:
> On 8/28/20 7:14 AM, junkes via Core-talk wrote:
>> Apparently I have no right to upload my RTEMS5 stuff to epics-base.
>> [h1@earth QtC-epics-base (7.0 *)]$ git push
>> Username for 'https://github.com': hjunkes
>> Password for 'https://hjunkes at github.com':
>> remote: Permission to epics-base/epics-base.git denied to hjunkes.
>> fatal: unable to access 'https://github.com/epics-base/epics-base.git/': The requested URL returned error: 403
>> What is the best way for me to continue here now?
> You should be able to push to https://github.com/hjunkes/epics-base
>> heinz
>> Changes to be committed:
>>   (use "git reset HEAD <file>..." to unstage)
>>         modified:   configure/CONFIG_COMMON
>>         modified:   configure/os/CONFIG.Common.RTEMS
>>         new file:   configure/os/CONFIG.Common.RTEMS-beagleboneblack
>>         modified:   configure/os/CONFIG.Common.RTEMS-beatnik
>>         modified:   configure/os/CONFIG.Common.RTEMS-pc386
>>         new file:   configure/os/CONFIG.Common.RTEMS-qoriq_e500
>>         new file:   configure/os/CONFIG.Common.RTEMS-xilinx_zynq_a9_qemu
>>         new file:   configure/os/CONFIG.Common.RTEMS-xilinx_zynq_zedboard
>>         modified:   configure/os/CONFIG.darwin-x86.Common
>>         modified:   configure/os/CONFIG_SITE.Common.RTEMS
>>         modified:   documentation/RELEASE_NOTES.md
>>         modified:   modules/libcom/RTEMS/Makefile
>>         modified:   modules/libcom/RTEMS/epicsMemFs.c
>>         modified:   modules/libcom/RTEMS/epicsMemFs.h
>>         new file:   modules/libcom/RTEMS/epicsNtp.c
>>         new file:   modules/libcom/RTEMS/epicsNtp.h
>>         modified:   modules/libcom/RTEMS/epicsRtemsInitHookPost.c
>>         modified:   modules/libcom/RTEMS/epicsRtemsInitHookPre.c
>>         modified:   modules/libcom/RTEMS/epicsRtemsInitHooks.h
>>         new file:   modules/libcom/RTEMS/kernel/epicsRtemsInitHookPost.c
>>         new file:   modules/libcom/RTEMS/kernel/epicsRtemsInitHookPre.c
>>         new file:   modules/libcom/RTEMS/kernel/epicsRtemsInitHooks.h
>>         renamed:    modules/libcom/RTEMS/rtems_config.c -> modules/libcom/RTEMS/kernel/rtems_config.c
>>         renamed:    modules/libcom/RTEMS/rtems_init.c -> modules/libcom/RTEMS/kernel/rtems_init.c
>>         renamed:    modules/libcom/RTEMS/rtems_netconfig.c -> modules/libcom/RTEMS/kernel/rtems_netconfig.c
>>         new file:   modules/libcom/RTEMS/kernel/setBootConfigFromNVRAM.c
>>         modified:   modules/libcom/RTEMS/ne2kpci.c
>>         new file:   modules/libcom/RTEMS/posix/epicsRtemsInitHookPost.c
>>         new file:   modules/libcom/RTEMS/posix/epicsRtemsInitHookPre.c
>>         new file:   modules/libcom/RTEMS/posix/epicsRtemsInitHooks.h
>>         new file:   modules/libcom/RTEMS/posix/libbsd_netconfig.c
>>         new file:   modules/libcom/RTEMS/posix/libbsd_netconfig.h
>>         new file:   modules/libcom/RTEMS/posix/rtems_config.c
>>         new file:   modules/libcom/RTEMS/posix/rtems_init.c
>>         new file:   modules/libcom/RTEMS/posix/setBootConfigFromNVRAM.c
>>         modified:   modules/libcom/RTEMS/rtems_util.c
>>         modified:   modules/libcom/RTEMS/setBootConfigFromNVRAM.c
>>         renamed:    modules/libcom/src/osi/os/RTEMS/devLibVMEOSD.c -> modules/libcom/src/osi/os/RTEMS-kernel/devLibVMEOSD.c
>>         renamed:    modules/libcom/src/osi/os/RTEMS/epicsAtomicOSD.cpp -> modules/libcom/src/osi/os/RTEMS-kernel/epicsAtomicOSD.cpp
>>         renamed:    modules/libcom/src/osi/os/RTEMS/epicsAtomicOSD.h -> modules/libcom/src/osi/os/RTEMS-kernel/epicsAtomicOSD.h
>>         renamed:    modules/libcom/src/osi/os/RTEMS/epicsMath.h -> modules/libcom/src/osi/os/RTEMS-kernel/epicsMath.h
>>         renamed:    modules/libcom/src/osi/os/RTEMS/osdEnv.c -> modules/libcom/src/osi/os/RTEMS-kernel/osdEnv.c
>>         renamed:    modules/libcom/src/osi/os/RTEMS/osdEvent.c -> modules/libcom/src/osi/os/RTEMS-kernel/osdEvent.c
>>         renamed:    modules/libcom/src/osi/os/RTEMS/osdEvent.h -> modules/libcom/src/osi/os/RTEMS-kernel/osdEvent.h
>>         renamed:    modules/libcom/src/osi/os/RTEMS/osdFindSymbol.c -> modules/libcom/src/osi/os/RTEMS-kernel/osdFindSymbol.c
>>         new file:   modules/libcom/src/osi/os/RTEMS-kernel/osdMessageQueue.c
>>         new file:   modules/libcom/src/osi/os/RTEMS-kernel/osdMessageQueue.h
>>         renamed:    modules/libcom/src/osi/os/RTEMS/osdMutex.c -> modules/libcom/src/osi/os/RTEMS-kernel/osdMutex.c
>>         renamed:    modules/libcom/src/osi/os/RTEMS/osdMutex.h -> modules/libcom/src/osi/os/RTEMS-kernel/osdMutex.h
>>         renamed:    modules/libcom/src/osi/os/RTEMS/osdPoolStatus.c -> modules/libcom/src/osi/os/RTEMS-kernel/osdPoolStatus.c
>>         renamed:    modules/libcom/src/osi/os/RTEMS/osdProcess.c -> modules/libcom/src/osi/os/RTEMS-kernel/osdProcess.c
>>         renamed:    modules/libcom/src/osi/os/RTEMS/osdReadline.c -> modules/libcom/src/osi/os/RTEMS-kernel/osdReadline.c
>>         new file:   modules/libcom/src/osi/os/RTEMS-kernel/osdSignal.cpp
>>         renamed:    modules/libcom/src/osi/os/RTEMS/osdSock.h -> modules/libcom/src/osi/os/RTEMS-kernel/osdSock.h
>>         renamed:    modules/libcom/src/osi/os/RTEMS/osdSpin.c -> modules/libcom/src/osi/os/RTEMS-kernel/osdSpin.c
>>         renamed:    modules/libcom/src/osi/os/RTEMS/osdStrtod.h -> modules/libcom/src/osi/os/RTEMS-kernel/osdStrtod.h
>>         renamed:    modules/libcom/src/osi/os/RTEMS/osdThread.c -> modules/libcom/src/osi/os/RTEMS-kernel/osdThread.c
>>         renamed:    modules/libcom/src/osi/os/RTEMS/osdThread.h -> modules/libcom/src/osi/os/RTEMS-kernel/osdThread.h
>>         renamed:    modules/libcom/src/osi/os/RTEMS/osdThreadExtra.c -> modules/libcom/src/osi/os/RTEMS-kernel/osdThreadExtra.c
>>         renamed:    modules/libcom/src/osi/os/RTEMS/osdTime.cpp -> modules/libcom/src/osi/os/RTEMS-kernel/osdTime.cpp
>>         renamed:    modules/libcom/src/osi/os/RTEMS/osdTime.h -> modules/libcom/src/osi/os/RTEMS-kernel/osdTime.h
>>         renamed:    modules/libcom/src/osi/os/RTEMS/osiUnistd.h -> modules/libcom/src/osi/os/RTEMS-kernel/osiUnistd.h
>>         new file:   modules/libcom/src/osi/os/RTEMS-posix/osdMessageQueue.c
>>         new file:   modules/libcom/src/osi/os/RTEMS-posix/osdMessageQueue.h
>>         new file:   modules/libcom/src/osi/os/RTEMS-posix/osdMutex.c
>>         new file:   modules/libcom/src/osi/os/RTEMS-posix/osdPoolStatus.c
>>         new file:   modules/libcom/src/osi/os/RTEMS-posix/osdSock.h
>>         modified:   modules/libcom/src/osi/os/RTEMS/epicsMMIO.h
>>         modified:   modules/libcom/src/osi/os/RTEMS/osdInterrupt.c
>>         modified:   modules/libcom/src/osi/os/RTEMS/osdInterrupt.h
>>         deleted:    modules/libcom/src/osi/os/RTEMS/osdSignal.cpp
>>         modified:   modules/libcom/src/osi/os/RTEMS/osdVME.h
>>         modified:   modules/libcom/src/osi/os/RTEMS/osiFileName.h
>> [h1@earth QtC-epics-base (7.0 *+)]$ git commit
>> [7.0 27e109de4] Porting to RTEMS5 with posix and libbsd
>>  73 files changed, 3325 insertions(+), 380 deletions(-)
>>  create mode 100644 configure/os/CONFIG.Common.RTEMS-beagleboneblack
>>  create mode 100644 configure/os/CONFIG.Common.RTEMS-qoriq_e500
>>  create mode 100644 configure/os/CONFIG.Common.RTEMS-xilinx_zynq_a9_qemu
>>  create mode 100644 configure/os/CONFIG.Common.RTEMS-xilinx_zynq_zedboard
>>  create mode 100644 modules/libcom/RTEMS/epicsNtp.c
>>  create mode 100644 modules/libcom/RTEMS/epicsNtp.h
>>  create mode 100644 modules/libcom/RTEMS/kernel/epicsRtemsInitHookPost.c
>>  create mode 100644 modules/libcom/RTEMS/kernel/epicsRtemsInitHookPre.c
>>  create mode 100644 modules/libcom/RTEMS/kernel/epicsRtemsInitHooks.h
>>  rename modules/libcom/RTEMS/{ => kernel}/rtems_config.c (91%)
>>  rename modules/libcom/RTEMS/{ => kernel}/rtems_init.c (93%)
>>  rename modules/libcom/RTEMS/{ => kernel}/rtems_netconfig.c (97%)
>>  create mode 100644 modules/libcom/RTEMS/kernel/setBootConfigFromNVRAM.c
>>  create mode 100644 modules/libcom/RTEMS/posix/epicsRtemsInitHookPost.c
>>  create mode 100644 modules/libcom/RTEMS/posix/epicsRtemsInitHookPre.c
>>  create mode 100644 modules/libcom/RTEMS/posix/epicsRtemsInitHooks.h
>>  create mode 100644 modules/libcom/RTEMS/posix/libbsd_netconfig.c
>>  create mode 100644 modules/libcom/RTEMS/posix/libbsd_netconfig.h
>>  create mode 100644 modules/libcom/RTEMS/posix/rtems_config.c
>>  create mode 100644 modules/libcom/RTEMS/posix/rtems_init.c
>>  create mode 100644 modules/libcom/RTEMS/posix/setBootConfigFromNVRAM.c
>>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/devLibVMEOSD.c (93%)
>>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/epicsAtomicOSD.cpp (100%)
>>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/epicsAtomicOSD.h (92%)
>>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/epicsMath.h (77%)
>>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdEnv.c (79%)
>>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdEvent.c (94%)
>>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdEvent.h (68%)
>>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdFindSymbol.c (72%)
>>  create mode 100644 modules/libcom/src/osi/os/RTEMS-kernel/osdMessageQueue.c
>>  create mode 100644 modules/libcom/src/osi/os/RTEMS-kernel/osdMessageQueue.h
>>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdMutex.c (92%)
>>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdMutex.h (68%)
>>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdPoolStatus.c (79%)
>>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdProcess.c (72%)
>>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdReadline.c (98%)
>>  create mode 100644 modules/libcom/src/osi/os/RTEMS-kernel/osdSignal.cpp
>>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdSock.h (98%)
>>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdSpin.c (98%)
>>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdStrtod.h (64%)
>>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdThread.c (80%)
>>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdThread.h (58%)
>>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdThreadExtra.c (75%)
>>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdTime.cpp (99%)
>>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdTime.h (96%)
>>  rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osiUnistd.h (80%)
>>  create mode 100644 modules/libcom/src/osi/os/RTEMS-posix/osdMessageQueue.c
>>  create mode 100644 modules/libcom/src/osi/os/RTEMS-posix/osdMessageQueue.h
>>  create mode 100644 modules/libcom/src/osi/os/RTEMS-posix/osdMutex.c
>>  create mode 100644 modules/libcom/src/osi/os/RTEMS-posix/osdPoolStatus.c
>>  create mode 100644 modules/libcom/src/osi/os/RTEMS-posix/osdSock.h
>>  delete mode 100644 modules/libcom/src/osi/os/RTEMS/osdSignal.cpp
No access to epics-base.git for push junkes via Core-talk
Re: No access to epics-base.git for push Michael Davidsaver via Core-talk
Prev: Re: No access to epics-base.git for push Michael Davidsaver via Core-talk
Next: Build failed: EPICS Base 7 base-7.0-72 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
ANJ, 28 Aug 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
