See <https://jenkins.aps.anl.gov/job/epics-example-linux32/801/display/redirect>
Changes:
Started by upstream project "epics-pva2pva-linux32" build number 193
originally caused by:
Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building remotely on linux32-1 (linux32) in workspace <https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/>
No credentials specified
Cloning the remote Git repository
Cloning repository https://github.com/epics-base/exampleCPP.git
> git init <https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/> # timeout=10
Fetching upstream changes from https://github.com/epics-base/exampleCPP.git
> git --version # timeout=10
> git --version # 'git version 1.7.1'
Setting http proxy: webproxy1.anl.gov:9091
> git fetch --tags --progress https://github.com/epics-base/exampleCPP.git +refs/heads/*:refs/remotes/origin/* # timeout=10
> git config remote.origin.url https://github.com/epics-base/exampleCPP.git # timeout=10
> git config --add remote.origin.fetch +refs/heads/*:refs/remotes/origin/* # timeout=10
Cleaning workspace
> git rev-parse --verify HEAD # timeout=10
No valid HEAD. Skipping the resetting
> git clean -fdx # timeout=10
> git rev-parse refs/remotes/origin/master^{commit} # timeout=10
> git rev-parse refs/remotes/origin/origin/master^{commit} # timeout=10
Checking out Revision 08d19008e1308b056f63116ae9f4cc5023e49bce (refs/remotes/origin/master)
> git config core.sparsecheckout # timeout=10
> git checkout -f 08d19008e1308b056f63116ae9f4cc5023e49bce # timeout=10
Commit message: "add tests for pvaClientCPP issue63"
> git rev-list --no-walk 08d19008e1308b056f63116ae9f4cc5023e49bce # timeout=10
[epics-example-linux32] $ /bin/sh -xe /tmp/jenkins4785250153346623883.sh
+ echo 'PVDATABASE = /local/jenkins/workspace/epics-pvDatabase-linux32'
+ echo 'PVACLIENT = /local/jenkins/workspace/epics-pvaClient-linux32'
+ echo 'PVA2PVA = /local/jenkins/workspace/epics-pva2pva-linux32'
+ echo 'PVACCESS = /local/jenkins/workspace/epics-pvAccess-linux32'
+ echo 'NORMATIVE = /local/jenkins/workspace/epics-normativeTypes-linux32'
+ echo 'PVDATA = /local/jenkins/workspace/epics-pvData-linux32'
+ echo 'PVCOMMON = /local/jenkins/workspace/epics-pvCommon-linux32'
+ echo 'EPICS_BASE = /local/jenkins/workspace/epics-base-3.16-linux32'
+ make linux-x86
configure/CONFIG:17: /local/jenkins/workspace/epics-base-3.16-linux32/configure/CONFIG: No such file or directory
configure/RULES_TOP:2: /local/jenkins/workspace/epics-base-3.16-linux32/configure/RULES_TOP: No such file or directory
make: *** No rule to make target '/local/jenkins/workspace/epics-base-3.16-linux32/configure/RULES_TOP'. Stop.
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: test/O.*/*.tap
Did not find any matching files.
- Build failed in Jenkins: epics-example-linux32 #802 APS Jenkins via Core-talk
Jenkins build is back to stable : epics-base-7.0-win64-test #220 APS Jenkins via Core-talk
RE: epicsExportShared symbols Mark Rivers via Core-talk
<2020>
2025
2026
Build failed: epics-base base-integration-584 AppVeyor via Core-talk
<2020>
2025
2026
