See <https://jenkins.aps.anl.gov/job/epics-example-linux32/802/display/redirect>
Changes:
Started by user Andrew Johnson
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building remotely on linux32-1 (linux32) in workspace <https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/>
No credentials specified
> git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url https://github.com/epics-base/exampleCPP.git # timeout=10
Cleaning workspace
> git rev-parse --verify HEAD # timeout=10
Resetting working tree
> git reset --hard # timeout=10
> git clean -fdx # timeout=10
Fetching upstream changes from https://github.com/epics-base/exampleCPP.git
> git --version # timeout=10
> git --version # 'git version 1.7.1'
Setting http proxy: webproxy1.anl.gov:9091
> git fetch --tags --progress https://github.com/epics-base/exampleCPP.git +refs/heads/*:refs/remotes/origin/* # timeout=10
> git rev-parse refs/remotes/origin/master^{commit} # timeout=10
> git rev-parse refs/remotes/origin/origin/master^{commit} # timeout=10
Checking out Revision 08d19008e1308b056f63116ae9f4cc5023e49bce (refs/remotes/origin/master)
> git config core.sparsecheckout # timeout=10
> git checkout -f 08d19008e1308b056f63116ae9f4cc5023e49bce # timeout=10
Commit message: "add tests for pvaClientCPP issue63"
> git rev-list --no-walk 08d19008e1308b056f63116ae9f4cc5023e49bce # timeout=10
[epics-example-linux32] $ /bin/sh -xe /tmp/jenkins2348666720428587735.sh
+ echo 'PVDATABASE = /local/jenkins/workspace/epics-pvDatabase-linux32'
+ echo 'PVACLIENT = /local/jenkins/workspace/epics-pvaClient-linux32'
+ echo 'PVA2PVA = /local/jenkins/workspace/epics-pva2pva-linux32'
+ echo 'PVACCESS = /local/jenkins/workspace/epics-pvAccess-linux32'
+ echo 'NORMATIVE = /local/jenkins/workspace/epics-normativeTypes-linux32'
+ echo 'PVDATA = /local/jenkins/workspace/epics-pvData-linux32'
+ echo 'PVCOMMON = /local/jenkins/workspace/epics-pvCommon-linux32'
+ echo 'EPICS_BASE = /local/jenkins/workspace/epics-base-3.16-linux32'
+ make linux-x86
make -C ./configure linux-x86
make[1]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/configure'>
perl -CSD /local/jenkins/workspace/epics-base-3.16-linux32/bin/linux-x86/makeMakefile.pl O.linux-x86 ../..
mkdir -p O.Common
make -C O.linux-x86 -f ../Makefile TOP=../.. T_A=linux-x86
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/configure/O.linux-x86'>
perl -CSD /local/jenkins/workspace/epics-base-3.16-linux32/bin/linux-x86/convertRelease.pl checkRelease
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/configure/O.linux-x86'>
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/configure'>
make -C ./database linux-x86
make[1]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database'>
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/configure'>
mkdir -p O.Common
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/configure/O.linux-x86'>
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/configure/O.linux-x86'>
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/configure'>
make -C ./src linux-x86
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/src'>
mkdir -p O.Common
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/src/O.linux-x86'>
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/local/jenkins/workspace/epics-pvDatabase-linux32/include -I/local/jenkins/workspace/epics-pvaClient-linux32/include -I/local/jenkins/workspace/epics-pvAccess-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include -MM -MF exampleHelloRPCClient.d ../exampleHelloRPCClient.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/local/jenkins/workspace/epics-pvDatabase-linux32/include -I/local/jenkins/workspace/epics-pvaClient-linux32/include -I/local/jenkins/workspace/epics-pvAccess-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include -MM -MF exampleDatabaseMain.d ../exampleDatabaseMain.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/local/jenkins/workspace/epics-pvDatabase-linux32/include -I/local/jenkins/workspace/epics-pvaClient-linux32/include -I/local/jenkins/workspace/epics-pvAccess-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include -MM -MF exampleSoftRecordRegister.d ../exampleSoftRecordRegister.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/local/jenkins/workspace/epics-pvDatabase-linux32/include -I/local/jenkins/workspace/epics-pvaClient-linux32/include -I/local/jenkins/workspace/epics-pvAccess-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include -MM -MF exampleDatabaseRegister.d ../exampleDatabaseRegister.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/local/jenkins/workspace/epics-pvDatabase-linux32/include -I/local/jenkins/workspace/epics-pvaClient-linux32/include -I/local/jenkins/workspace/epics-pvAccess-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include -MM -MF exampleDatabase.d ../exampleDatabase.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/local/jenkins/workspace/epics-pvDatabase-linux32/include -I/local/jenkins/workspace/epics-pvaClient-linux32/include -I/local/jenkins/workspace/epics-pvAccess-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include -MM -MF exampleHelloRPCRecord.d ../exampleHelloRPCRecord.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/local/jenkins/workspace/epics-pvDatabase-linux32/include -I/local/jenkins/workspace/epics-pvaClient-linux32/include -I/local/jenkins/workspace/epics-pvAccess-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include -MM -MF exampleSoftRecord.d ../exampleSoftRecord.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/local/jenkins/workspace/epics-pvDatabase-linux32/include -I/local/jenkins/workspace/epics-pvaClient-linux32/include -I/local/jenkins/workspace/epics-pvAccess-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include -MM -MF exampleHelloRecord.d ../exampleHelloRecord.cpp
Installing dbd file ../../dbd/exampleDatabaseRegister.dbd
mkdir ../../dbd
Installing dbd file ../../dbd/exampleSoftRecordRegister.dbd
Installing generic include file ../../include/pv/exampleHelloRecord.h
mkdir ../../include
mkdir ../../include/pv
Installing generic include file ../../include/pv/exampleHelloRPCRecord.h
Installing generic include file ../../include/pv/exampleSoftRecord.h
Installing generic include file ../../include/pv/exampleDatabase.h
make[3]: *** No rule to make target '../../lib/linux-x86/libnt.a', needed by 'libexampleDatabase.a'. Stop.
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/src/O.linux-x86'>
/local/jenkins/workspace/epics-base-3.16-linux32/configure/RULES_ARCHS:62: recipe for target 'linux-x86' failed
make[2]: *** [linux-x86] Error 2
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/src'>
/local/jenkins/workspace/epics-base-3.16-linux32/configure/RULES_DIRS:84: recipe for target 'src.linux-x86' failed
make[1]: *** [src.linux-x86] Error 2
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database'>
/local/jenkins/workspace/epics-base-3.16-linux32/configure/RULES_DIRS:84: recipe for target 'database.linux-x86' failed
make: *** [database.linux-x86] Error 2
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: test/O.*/*.tap
Did not find any matching files.
- Jenkins build is back to normal : epics-example-linux32 #803 APS Jenkins via Core-talk
- Build failed in Jenkins: epics-example-linux32 #801 APS Jenkins via Core-talk
Build failed: epics-base base-inspect-compiler-586 AppVeyor via Core-talk
Re: Opinions please, what should this database do Johnson, Andrew N. via Core-talk
<2020>
2025
2026
<2020>
2025
2026
