2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: ABI compatibility with different C++ standard versions
From: "Konrad, Martin via Core-talk" <core-talk at aps.anl.gov>
To: Ralph Lange <ralph.lange at gmx.de>, EPICS Core Talk <core-talk at aps.anl.gov>
Date: Thu, 8 Oct 2020 16:30:29 +0000
Hi Ralph,
> ITER needed to switch EPICS Base to use "-std=c++11" because without
> that setting, linking EPICS libraries would not work for other code that
> was compiled using C++11.
Weird. I tried to reproduce this by building pvxs (which builds using
-std=c++11) on CentOS 7 against EPICS 7 (built without -std=c++11).
Works fine for me.
Are you linking against any libraries provided by a vendor as binaries?
Is there a way we can reproduce the problem?
Martin
Martin Konrad
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: konrad at frib.msu.edu
# -*- mode: ruby -*-
# vi: set ft=ruby :
# All Vagrant configuration is done below. The "2" in Vagrant.configure
# configures the configuration version (we support older styles for
# backwards compatibility). Please don't change it unless you know what
# you're doing.
Vagrant.configure("2") do |config|
  # The most common configuration options are documented and commented below.
  # For a complete reference, please see the online documentation at
  # https://docs.vagrantup.com.
  # Every Vagrant development environment requires a box. You can search for
  # boxes at https://vagrantcloud.com/search.
  config.vm.box = "centos/7"
  # Disable automatic box update checking. If you disable this, then
  # boxes will only be checked for updates when the user runs
  # `vagrant box outdated`. This is not recommended.
  # config.vm.box_check_update = false
  # Create a forwarded port mapping which allows access to a specific port
  # within the machine from a port on the host machine. In the example below,
  # accessing "localhost:8080" will access port 80 on the guest machine.
  # NOTE: This will enable public access to the opened port
  # config.vm.network "forwarded_port", guest: 80, host: 8080
  # within the machine from a port on the host machine and only allow access
  # via 127.0.0.1 to disable public access
  # config.vm.network "forwarded_port", guest: 80, host: 8080, host_ip: "127.0.0.1"
  # Create a private network, which allows host-only access to the machine
  # using a specific IP.
  # config.vm.network "private_network", ip: "192.168.33.10"
  # Create a public network, which generally matched to bridged network.
  # Bridged networks make the machine appear as another physical device on
  # your network.
  # config.vm.network "public_network"
  # Share an additional folder to the guest VM. The first argument is
  # the path on the host to the actual folder. The second argument is
  # the path on the guest to mount the folder. And the optional third
  # argument is a set of non-required options.
  # config.vm.synced_folder "../data", "/vagrant_data"
  # Provider-specific configuration so you can fine-tune various
  # backing providers for Vagrant. These expose provider-specific options.
  # Example for VirtualBox:
  # config.vm.provider "virtualbox" do |vb|
  #   # Display the VirtualBox GUI when booting the machine
  #   vb.gui = true
  #   # Customize the amount of memory on the VM:
  #   vb.memory = "1024"
  # end
  # View the documentation for the provider you are using for more
  # information on available options.
  # Enable provisioning with a shell script. Additional provisioners such as
  # Ansible, Chef, Docker, Puppet and Salt are also available. Please see the
  # documentation for more information about their specific syntax and use.
  config.vm.provision "shell", inline: <<-SHELL
    yum check-update
    yum -y update
    yum -y install gcc gcc-c++ git libevent-devel
    git clone https://github.com/epics-base/epics-base.git
    git clone https://github.com/mdavidsaver/pvxs.git
    cd epics-base/
    make
    echo 'EPICS_BASE=/home/vagrant/epics-base' > /home/vagrant/RELEASE.local
    cd /home/vagrant/pvxs/
    make
  SHELL
end
Re: ABI compatibility with different C++ standard versions Michael Davidsaver via Core-talk
ABI compatibility with different C++ standard versions Konrad, Martin via Core-talk
Re: ABI compatibility with different C++ standard versions Ralph Lange via Core-talk
Prev: Re: ABI compatibility with different C++ standard versions Ralph Lange via Core-talk
Next: Re: ABI compatibility with different C++ standard versions Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
ANJ, 08 Oct 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
