2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Build failed: EPICS Base 7 base-3.15-91
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Ralph Lange <Ralph.Lange at gmx.de>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Thu, 22 Oct 2020 18:50:51 +0000
Hi Ralph,
This build failed all vs2015 and older and mingw config's. For vs2015 it appears to be a Perl issue (missing ExtUtils::Command module), for vs2013 and below it can’t find the compilers (cl and gcc).
However probably more fundamentally, why is the epics-base-7 Appveyor project compiling the 3.15 branch at all? The epics-base-3 Appveyor project is currently happily building these commits and has got past the config's that failed in the other project.
- Andrew
On Oct 22, 2020, at 12:55 PM, AppVeyor via Core-talk <core-talk at aps.anl.gov> wrote:
Build EPICS Base 7 base-3.15-91 failed
Commit 228ad79b7a by Martin Konrad on 10/13/2020 10:38 PM:
Simplify addToList() function
Configure your notification preferences
Complexity comes for free, simplicity you have to work for.
Re: Build failed: EPICS Base 7 base-3.15-91 Ralph Lange via Core-talk
Build failed: EPICS Base 7 base-3.15-91 AppVeyor via Core-talk
Prev: Build failed: EPICS Base 7 base-3.15-91 AppVeyor via Core-talk
Next: Jenkins build became unstable: epics-7.0 » linux32 #264 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: Build failed: EPICS Base 7 base-3.15-91 Ralph Lange via Core-talk
ANJ, 02 Nov 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
