Fixed.
(Settings were wrong and didn't use the special "7.0 only" appveyor.yml from the gist.)
I won't dive into the build failures as the same commit was built fine under the epics-base-3.15 project and wasn't supposed to be built here anyway.
Cheers, ~Ralph
On Thu, 22 Oct 2020 at 20:50, Johnson, Andrew N. < anj at anl.gov> wrote:
Hi Ralph,
This build failed all vs2015 and older and mingw config's. For vs2015 it appears to be a Perl issue (missing ExtUtils::Command module), for vs2013 and below it can’t find the compilers (cl and gcc).
However probably more fundamentally, why is the epics-base-7 Appveyor project compiling the 3.15 branch at all? The epics-base-3 Appveyor project is currently happily building these commits and has got past the config's that failed in the other
project.
- Andrew
Complexity comes for free, simplicity you have to work for.
- Build failed: EPICS Base 7 base-3.15-91 AppVeyor via Core-talk
- Re: Build failed: EPICS Base 7 base-3.15-91 Johnson, Andrew N. via Core-talk
[Bug 1902285] [NEW] caput never uses ca_get_callback() Andrew Johnson via Core-talk
[Bug 1902560] [NEW] Read info items using a filter Andrew Johnson via Core-talk
<2020>
2025
2026
Jenkins build became unstable: epics-7.0 » linux32 #264 APS Jenkins via Core-talk
<2020>
2025
2026
ANJ, 02 Nov 2020 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
