2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: [Bug 1902560] [NEW] Read info items using a filter
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Mon, 02 Nov 2020 18:12:00 -0000
Public bug reported:
Info items are currently only accessible from inside the IOC, but a few
people have asked if they could be fetched over the network. The
simplest way to implement that is probably with a server-side filter,
which makes this functionality optional and decouples the code from the
internals of the IOC.
The filter could accept parameters to control what it returns, such as:
1. A list of all the info item names attached to this record or alias.
2. A list of info item names attached that match a particular pattern.
3. Number of info items attached.
4. Value of a specific info item, selected by index number or item name.
5. All info item names and values, formatted as a JSON object (beware that item values can now themselves be JSON objects, don't assume they are just a string).
It would be reasonable to limit item names to 39 characters so #1 and #2
above could return an array of DBF_STRINGs, and #3 could return a
DBF_SHORT or DBF_LONG, but item values can be much longer so the return
types of #4 and #5 would need to be an array of DBF_CHAR with some
chosen maximum length.
CAUTION: Record aliases have their own info item namespace, separate
from the record they alias:
record(ai, ai1) {
  info(tag1, "record")
  alias(al1)
record("*", al1) {
  info(tag2, "alias")
epics> dbli
ai1 info(tag1, "record")
al1 info(tag2, "alias")
** Affects: epics-base
     Importance: Wishlist
         Status: Confirmed
** Tags: codeathon
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1902560
Title:
Status in EPICS Base:
  Confirmed
Bug description:
  few people have asked if they could be fetched over the network. The
  the internals of the IOC.
  as:
  #2 above could return an array of DBF_STRINGs, and #3 could return a
  return types of #4 and #5 would need to be an array of DBF_CHAR with
  some chosen maximum length.
  record(ai, ai1) {
    alias(al1)
  record("*", al1) {
    info(tag2, "alias")
  epics> dbli
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1902560/+subscriptions
Prev: Re: Build failed: EPICS Base 7 base-3.15-91 Ralph Lange via Core-talk
Next: Build failed: EPICS Base 7 base-7.0-94 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: [Bug 1902285] [NEW] caput never uses ca_get_callback() Andrew Johnson via Core-talk
ANJ, 02 Nov 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
