2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: make puzzle
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: "Johnson, Andrew N." <anj at anl.gov>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Mon, 9 Nov 2020 11:14:50 -0800
On 11/6/20 4:00 PM, Johnson, Andrew N. wrote:
> For the workstation arch's we have already linked all those target-specific libraries into libCom.so when we created that (LDLIBS is appended to SHRLIB_LDLIBS unconditionally, which is used instead of PROD_LDLIBS for lib.so linking), so there is no need to link against them again. If you aren’t linking your executable with libCom you'd probably need a different set of system libraries anyway.
In the last sentence, when you write "probably".  Do you see this as truly optional?
If so, then you and I may not be disagreeing on this point after all.
In thinking about this, the apparent contradiction I see is that SHARED_LIBRARIES
seems to be used both as a proxy for whether the dependency libCom.so was built, and
whether a local library libwhatever.so will be built.  To me mind these are independent
choices.
If the first part is my misunderstanding, then I no longer see a contradiction,
and we agree that SHARED_LIBRARIES is strictly used to control local library builds.
If this is the case, then do you agree that the original "puzzle":
> LDLIBS_STATIC_YES = LDLIBS
> LDLIBS_SHARED_NO = LDLIBS
> PROD_LDLIBS += $($(firstword $(LDLIBS_STATIC_$(STATIC_BUILD)) \
>               $(LDLIBS_SHARED_$(SHARED_LIBRARIES))))
Could be simplified to:
> PROD_LDLIBS += $(LDLIBS)
With the only "ill" effect being over-linked executables?
over-linking being a "problem" we already have as a side effect of combining
both direct and indirect dependencies in PROD_LIBS to facilitate static linking.
make puzzle Michael Davidsaver via Core-talk
Re: make puzzle Johnson, Andrew N. via Core-talk
Prev: Re: make puzzle Ralph Lange via Core-talk
Next: epics-pva2pva-linux32 - Build # 197 - Unstable! APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Next: epics-7.0 - Build # 268 - Still unstable! APS Jenkins via Core-talk
ANJ, 11 Nov 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
