2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: another git question
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: "Zimoch Dirk (PSI)" <dirk.zimoch at psi.ch>
Cc: "'core-talk at aps.anl.gov'" <core-talk at aps.anl.gov>
Date: Wed, 18 Nov 2020 09:56:25 -0800
On 11/18/20 7:56 AM, Zimoch Dirk (PSI) via Core-talk wrote:
> Will git be able to handle files that have been moved to a different path?
Most of the time, yes.  Though there can be confusion
when eg. both a move and a rename are detected.
Some of the osd*.c files do this.
Before merging you will probably want to set:
> git config --global diff.renameLimit 0
This overrides a conservative default intended to speed
up merges of very large projects (aka. the linux kernel).
I've never had noticed this with Base.
cf. 'man git-config'
AW: another git question Zimoch Dirk (PSI) via Core-talk
Prev: Re: another git question Konrad, Martin via Core-talk
Next: Re: AW: Problems with hanging osiSockTest Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Next: AW: another git question Zimoch Dirk (PSI) via Core-talk
ANJ, 19 Nov 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
