2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: AW: AW: AW: Problems with hanging osiSockTest
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: "Zimoch Dirk (PSI)" <dirk.zimoch at psi.ch>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Fri, 20 Nov 2020 07:42:36 -0800
On 11/20/20 12:49 AM, Zimoch Dirk (PSI) wrote:
> Which this change, the tests terminates and succeeds.
> Please do not have variable declarations after instructions in C (non C++) code. Not all compilers like that. I already had to fix udpSockFanoutTestRx() because of this problem:
How could we expand our CI coverage to discover this?
Do your CI builds cover this case?  (a non-MS compiler
which still imposes this C89 ordering restriction by
default)
> @@ -213,6 +213,7 @@ void udpSockFanoutTestRx(void* raw)
>      struct TInfo *info = raw;
>      epicsTimeStamp start, now;
> +    unsigned nremain = nrepeat;
>  #ifdef _WIN32
>      /* ms */
>      DWORD timeout = 10000;
> @@ -222,7 +223,6 @@ void udpSockFanoutTestRx(void* raw)
>      timeout.tv_sec = 10;
>      timeout.tv_usec = 0;
>  #endif
> -    unsigned nremain = nrepeat;
>      (void)epicsTimeGetCurrent(&start);
>      now = start;
> Dirk
>> -----Ursprüngliche Nachricht-----
>> Von: Michael Davidsaver <mdavidsaver at gmail.com>
>> Gesendet: Donnerstag, 19. November 2020 19:24
>> An: Zimoch Dirk (PSI) <dirk.zimoch at psi.ch>
>> Cc: Johnson, Andrew N. <anj at anl.gov>; EPICS core-talk <core-
>> Betreff: Re: AW: AW: Problems with hanging osiSockTest
>> On 11/19/20 2:27 AM, Zimoch Dirk (PSI) wrote:
>>> I have tested the latest 7.0 commit.
>>> osiSockTest still hangs on the virbr0 interface:
>> Ha.  I see why my attempt to have this test timeout is broken.
>>> diff --git a/modules/libcom/test/osiSockTest.c
>> b/modules/libcom/test/osiSockTest.c
>>> index e71eec5fe..a3b831b66 100644
>>> --- a/modules/libcom/test/osiSockTest.c
>>> +++ b/modules/libcom/test/osiSockTest.c
>>> @@ -239,6 +239,8 @@ void udpSockFanoutTestRx(void* raw)
>>>          osiSockAddr src;
>>>          osiSocklen_t srclen = sizeof(src);
>>> +        (void)epicsTimeGetCurrent(&now);
>>>          int n = recvfrom(info->sock, buf.bytes, sizeof(buf.bytes), 0, &src.sa,
>> &srclen);
>>>          buf.bytes[sizeof(buf.bytes)-1] = '\0';
Re: AW: AW: AW: Problems with hanging osiSockTest Ralph Lange via Core-talk
Problems with hanging osiSockTest Zimoch Dirk (PSI) via Core-talk
Re: Problems with hanging osiSockTest Johnson, Andrew N. via Core-talk
AW: Problems with hanging osiSockTest Zimoch Dirk (PSI) via Core-talk
Re: AW: Problems with hanging osiSockTest Michael Davidsaver via Core-talk
AW: AW: Problems with hanging osiSockTest Zimoch Dirk (PSI) via Core-talk
Re: AW: AW: Problems with hanging osiSockTest Michael Davidsaver via Core-talk
AW: AW: AW: Problems with hanging osiSockTest Zimoch Dirk (PSI) via Core-talk
Prev: Re: AW: Problems with hanging osiSockTest Michael Davidsaver via Core-talk
Next: Re: AW: AW: AW: Problems with hanging osiSockTest Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: AW: AW: AW: Problems with hanging osiSockTest Zimoch Dirk (PSI) via Core-talk
ANJ, 20 Nov 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
