Which this change, the tests terminates and succeeds.
Please do not have variable declarations after instructions in C (non C++) code. Not all compilers like that. I already had to fix udpSockFanoutTestRx() because of this problem:
@@ -213,6 +213,7 @@ void udpSockFanoutTestRx(void* raw)
struct TInfo *info = raw;
epicsTimeStamp start, now;
+ unsigned nremain = nrepeat;
#ifdef _WIN32
/* ms */
DWORD timeout = 10000;
@@ -222,7 +223,6 @@ void udpSockFanoutTestRx(void* raw)
timeout.tv_sec = 10;
timeout.tv_usec = 0;
#endif
- unsigned nremain = nrepeat;
(void)epicsTimeGetCurrent(&start);
now = start;
Dirk
> -----Ursprüngliche Nachricht-----
> Von: Michael Davidsaver <mdavidsaver at gmail.com>
> Gesendet: Donnerstag, 19. November 2020 19:24
> An: Zimoch Dirk (PSI) <dirk.zimoch at psi.ch>
> Cc: Johnson, Andrew N. <anj at anl.gov>; EPICS core-talk <core-
> talk at aps.anl.gov>
> Betreff: Re: AW: AW: Problems with hanging osiSockTest
> On 11/19/20 2:27 AM, Zimoch Dirk (PSI) wrote:
> > I have tested the latest 7.0 commit.
> > osiSockTest still hangs on the virbr0 interface:
> Ha. I see why my attempt to have this test timeout is broken.
> > diff --git a/modules/libcom/test/osiSockTest.c
> b/modules/libcom/test/osiSockTest.c
> > index e71eec5fe..a3b831b66 100644
> > --- a/modules/libcom/test/osiSockTest.c
> > +++ b/modules/libcom/test/osiSockTest.c
> > @@ -239,6 +239,8 @@ void udpSockFanoutTestRx(void* raw)
> > osiSockAddr src;
> > osiSocklen_t srclen = sizeof(src);
> > + (void)epicsTimeGetCurrent(&now);
> > int n = recvfrom(info->sock, buf.bytes, sizeof(buf.bytes), 0, &src.sa,
> &srclen);
> > buf.bytes[sizeof(buf.bytes)-1] = '\0';
- Re: AW: AW: AW: Problems with hanging osiSockTest Michael Davidsaver via Core-talk
- Problems with hanging osiSockTest Zimoch Dirk (PSI) via Core-talk
- Re: Problems with hanging osiSockTest Johnson, Andrew N. via Core-talk
- AW: Problems with hanging osiSockTest Zimoch Dirk (PSI) via Core-talk
- Re: AW: Problems with hanging osiSockTest Michael Davidsaver via Core-talk
- AW: AW: Problems with hanging osiSockTest Zimoch Dirk (PSI) via Core-talk
- Re: AW: AW: Problems with hanging osiSockTest Michael Davidsaver via Core-talk
Re: another git question Yendell, Gary (DLSLtd, RAL, LSCI) via Core-talk
<2020>
2025
2026
<2020>
2025
2026
