2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: AW: AW: Problems with hanging osiSockTest
From: "Zimoch Dirk \(PSI\) via Core-talk" <core-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>
Cc: "'core-talk at aps.anl.gov'" <core-talk at aps.anl.gov>
Date: Fri, 20 Nov 2020 08:36:14 +0000
Bringing the virbr0 interface down makes the test succeed.
iptables -L reports:
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
ACCEPT     udp  --  anywhere             anywhere             udp dpt:domain
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:domain
ACCEPT     udp  --  anywhere             anywhere             udp dpt:bootps
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:bootps
DROP       udp  --  anywhere             anywhere             udp dpt:ca-1
Chain FORWARD (policy ACCEPT)
ACCEPT     all  --  anywhere             192.168.122.0/24     ctstate RELATED,ESTABLISHED
ACCEPT     all  --  192.168.122.0/24     anywhere
ACCEPT     all  --  anywhere             anywhere
REJECT     all  --  anywhere             anywhere             reject-with icmp-port-unreachable
Chain OUTPUT (policy ACCEPT)
ACCEPT     udp  --  anywhere             anywhere             udp dpt:bootpc
> -----Ursprüngliche Nachricht-----
> Von: Michael Davidsaver <mdavidsaver at gmail.com>
> Gesendet: Donnerstag, 19. November 2020 19:11
> An: Zimoch Dirk (PSI) <dirk.zimoch at psi.ch>
> Cc: 'core-talk at aps.anl.gov' <core-talk at aps.anl.gov>
> Betreff: Re: AW: Problems with hanging osiSockTest
> On 11/19/20 2:11 AM, Zimoch Dirk (PSI) via Core-talk wrote:
> > I have just noticed that I had sent this only to Andrew, not to the core-talk list.
> > The problematic interface is "virbr0" which may have something to do with
> VmWare being installed on the system. or maybe docker?
> Have you checked for firewall (iptables or nft) rules for this interface?
> The fact that all the packet counters are zero suggests that it isn't
> being used so often.  Can you try to disable it temporarily?  ("ifconfig virbr0
> down")
> Let's make sure we're chasing the real problem.
> > *Von:*Zimoch Dirk (PSI)
> > *Gesendet:* Mittwoch, 18. November 2020 13:34
> > *An:* Zimoch Dirk (PSI) <dirk.zimoch at psi.ch>; Johnson, Andrew N.
> <anj at anl.gov>
> > *Betreff:* AW: Problems with hanging osiSockTest
> > $ ifconfig
> > enp0s31f6: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
> >         inet 129.129.130.117  netmask 255.255.255.0  broadcast 129.129.130.255
> >         inet6 fe80::42b0:34ff:feea:5428  prefixlen 64  scopeid 0x20<link>
> >         ether 40:b0:34:ea:54:28  txqueuelen 1000  (Ethernet)
> >         RX packets 54764087  bytes 24015803269 (22.3 GiB)
> >         RX errors 0  dropped 0  overruns 0  frame 0
> >         TX packets 55167521  bytes 54881613829 (51.1 GiB)
> >         TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
> >         device interrupt 16  memory 0xe1200000-e1220000
> > lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
> >         inet 127.0.0.1  netmask 255.0.0.0
> >         inet6 ::1  prefixlen 128  scopeid 0x10<host>
> >         loop  txqueuelen 1000  (Local Loopback)
> >         RX packets 1322943  bytes 739804353 (705.5 MiB)
> >         TX packets 1322943  bytes 739804353 (705.5 MiB)
> > virbr0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
> >         inet 192.168.122.1  netmask 255.255.255.0  broadcast 192.168.122.255
> >         ether 52:54:00:15:9b:3e  txqueuelen 1000  (Ethernet)
> >         RX packets 0  bytes 0 (0.0 B)
> >         TX packets 0  bytes 0 (0.0 B)
> > *Von:*Core-talk <core-talk-bounces at aps.anl.gov <mailto:core-talk-
> bounces at aps.anl.gov>> *Im Auftrag von *Zimoch Dirk (PSI) via Core-talk
> > *Gesendet:* Mittwoch, 18. November 2020 13:33
> > *An:* Johnson, Andrew N. <anj at anl.gov <mailto:anj at anl.gov>>
> > *Cc:* EPICS core-talk <core-talk at aps.anl.gov <mailto:core-
> talk at aps.anl.gov>>
> > After this:
> > 1..24
> > ok  1 - osiSockAttach
> > # udpSockTest()
> > ok  2 - epicsSocketCreate INET, DGRAM, 0
> > ok  3 - setsockopt BROADCAST := 1
> > ok  4 - getsockopt BROADCAST => 1
> > ok  5 - setsockopt BROADCAST := 0
> > ok  6 - getsockopt BROADCAST => 0
> > ok  7 - setsockopt MULTICAST_LOOP := 1
> > ok  8 - getsockopt MULTICAST_LOOP => 1
> > ok  9 - setsockopt MULTICAST_LOOP := 0
> > ok 10 - getsockopt MULTICAST_LOOP => 0
> > ok 11 - setsockopt IP_MULTICAST_TTL := 2
> > ok 12 - getsockopt IP_MULTICAST_TTL => 2
> > ok 13 - setsockopt IP_MULTICAST_TTL := 1
> > ok 14 - getsockopt IP_MULTICAST_TTL => 1
> > # udpSockFanoutBindTest()
> > # First test if epicsSocketEnableAddressUseForDatagramFanout() is necessary
> > ok 15 - bind() to port 43731
> > ok 16 - bind() to 43731 error -1, 98
> > # Now the real test
> > ok 17 - bind() to port 43731
> > ok 18 - bind() to port 43731
> > # udpSockFanoutTest()
> > # Interface 129.129.130.255:5064
> > # Not LO
> > # RX1 start
> > # RX2 start
> > # RX ignore
> > # RX ignore
> > # RX2 success 0
> > # RX1 success 0
> > # RX ignore
> > # RX ignore
> > # RX ignore
> > # RX ignore
> > # RX ignore
> > # RX ignore
> > # RX2 success 1
> > # RX1 success 1
> > # RX ignore
> > # RX ignore
> > # RX2 success 2
> > # RX1 success 2
> > # RX ignore
> > # RX ignore
> > # RX2 success 3
> > # RX1 success 3
> > # RX ignore
> > # RX ignore
> > # RX ignore
> > # RX ignore
> > # RX1 success 4
> > # RX2 success 4
> > # RX ignore
> > # RX ignore
> > # RX ignore
> > # RX ignore
> > # RX1 success 5
> > # RX1 end
> > # RX2 success 5
> > # RX2 end
> > # Result: RX1 3f:0 RX2 3f:0
> > # Interface 192.168.122.255:5064
> > # Not LO
> > # RX1 start
> > # RX2 start
> > # RX ignore
> > Now it repeatedly prints "# RX ignore" forever...
> > *Von:*Johnson, Andrew N. <anj at anl.gov <mailto:anj at anl.gov>>
> > *Gesendet:* Dienstag, 17. November 2020 18:11
> > *An:* Zimoch Dirk (PSI) <dirk.zimoch at psi.ch <mailto:dirk.zimoch at psi.ch>>
> > *Betreff:* Re: Problems with hanging osiSockTest
> > Dirk,
> > What happens if you run that test manually? All EPICS unit tests can be run
> individually without using the test harness to see more details as the test
> proceeds. This is my output on RHEL-7.8, which takes about 6 seconds to run:
> >     *tux% *cd modules/libcom/test/O.linux-x86_64/
> >     *tux% *./osiSockTest
> >     1..24
> >     # udpSockTest()
> necessary
> >     ok 15 - bind() to port 55467
> >     ok 16 - bind() to 55467 error -1, 98
> >     # Now the real test
> >     ok 17 - bind() to port 55467
> >     ok 18 - bind() to port 55467
> >     # Interface 164.54.11.255:5064
> >     # Not LO
> >     # RX1 start
> >     # RX2 start
> >     # RX2 success 0
> >     # RX1 success 0
> >     # RX2 success 1
> >     # RX1 success 1
> >     # RX2 success 2
> >     # RX1 success 2
> >     # RX ignore
> >     # RX ignore
> >     # RX1 success 3
> >     # RX2 success 3
> >     # RX2 success 4
> >     # RX1 success 4
> >     # RX1 success 5
> >     # RX1 end
> >     # RX2 success 5
> >     # RX2 end
> >     # Not LO
> >     # RX1 start
> >     # RX2 start
> >     # RX1 success 0
> >     # RX2 success 0
> >     # RX1 success 1
> >     # RX2 success 1
> >     # RX1 success 2
> >     # RX2 success 2
> >     # RX ignore
> >     # RX ignore
> >     # RX1 success 3
> >     # RX2 success 3
> >     # RX1 success 4
> >     # RX2 success 4
> >     # RX1 success 5
> >     # RX1 end
> >     # RX2 success 5
> >     # RX2 end
> >     ok 19 - Found non-loopback interface
> >     ok 20 - Successes 2
> >     # tcpSockReuseBindTest(0)
> >     ok 21 - bind() to port 53058
> >     ok 22 - bind() to 53058 error -1, 98
> >     # tcpSockReuseBindTest(1)
> >     # epicsSocketEnableAddressReuseDuringTimeWaitState
> >     ok 23 - bind() to port 34068
> >     ok 24 - bind() to 34068 error -1, 98
> >         Results
> >            Tests: 24
> >           Passed:  24 = 100.00%
> > - Andrew
> >     On Nov 17, 2020, at 4:47 AM, Zimoch Dirk (PSI) via Core-talk <core-
> talk at aps.anl.gov <mailto:core-talk at aps.anl.gov>> wrote:
> >     Hello everybody,
> >     I have problems with a test in EPICS 7 commit
> 8fd36d8eef3420b42e7936e949928a6b43df7e15.
> >     osiSockTest seems to take forever.
> >     'make runtests' hangs here:
> >     osiSockTest.t ................. 1/24
> >     'make tapfiles' hangs here:
> >     perl -CSD osiSockTest.t -tap > osiSockTest.tap
> >     I am testing on RedHat 7 (linux-x86_64).
> >     Any ideas?
> >     Dirk
> > Complexity comes for free, simplicity you have to work for.
Re: AW: Problems with hanging osiSockTest Ralph Lange via Core-talk
Problems with hanging osiSockTest Zimoch Dirk (PSI) via Core-talk
Re: Problems with hanging osiSockTest Johnson, Andrew N. via Core-talk
AW: Problems with hanging osiSockTest Zimoch Dirk (PSI) via Core-talk
Re: AW: Problems with hanging osiSockTest Michael Davidsaver via Core-talk
Prev: Build failed: epics-base base-7.0-602 AppVeyor via Core-talk
Next: AW: AW: AW: Problems with hanging osiSockTest Zimoch Dirk (PSI) via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: AW: Problems with hanging osiSockTest Michael Davidsaver via Core-talk
Next: Re: AW: Problems with hanging osiSockTest Ralph Lange via Core-talk
ANJ, 20 Nov 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
