2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: mp+394327 at code.launchpad.net
Date: Mon, 23 Nov 2020 15:56:58 -0000
We found that EPICS was not behaving as "real-time" as expected even though SCHED_FIFO was used. A deeper investigation found that this was due to prioriy inversion. When reading the source code, we found that "Until these can be demonstrated to work leave them undefined" has been in for a long time and nobody seemed to have cared, which had surprized us a lot. I think this wither got forgotten somehow and nobody really needed it or noticed it or maybe people simply removed those #undefs (which is not sufficient because other code used posix semaphores directly instead of using epicsMutexes).
I propose this change now, because we have fixed it now.
Till needs to comment on details of the implementation...
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/394327
Your team EPICS Core Developers is requested to review the proposed merge of ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0.
Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Till Straumann via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 mdavidsaver via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 23 Nov 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
