2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0
From: mdavidsaver via Core-talk <core-talk at aps.anl.gov>
To: mp+394327 at code.launchpad.net
Date: Mon, 23 Nov 2020 16:16:50 -0000
I tried the simply minded (early morning) test of removing the two #undef lines.  It seems like to have the desired effect.  pthread_mutexattr_setprotocol(..., PTHREAD_PRIO_INHERIT) succeeds with for a normal unprivleged user.  I added some prints to confirm that status==0.
Am I missing something obvious?
I'm testing with Debian 10, where _XOPEN_SOURCE=700 (by way of -D_GNU_SOURCE).
Also, what is the motivation to economize pthread_mutexattr_t?  I see __SIZEOF_PTHREAD_MUTEXATTR_T==4 (on a 64-bit host).
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/394327
Your team EPICS Core Developers is requested to review the proposed merge of ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0.
Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Till Straumann via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Till Straumann via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 24 Nov 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
