2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1873406] Re: EpicsHostArch script does not detect recent MSYS2/MinGW setups on Windows
From: Ralph Lange via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Thu, 26 Nov 2020 15:11:17 -0000
windows-x64-mingw
Complete rewrite of the Windows README is under review.
Find the PullRequest here:
https://epics--9.org.readthedocs.build/projects/how-tos/en/9/getting-started/installation-windows.html
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1873406
Title:
  Windows
Status in EPICS Base:
  Triaged
Status in EPICS Base 3.15 series:
  New
Status in EPICS Base 7.0 series:
  Triaged
Bug description:
  On MSYS2/MinGW installations, the EpicsHostArch script does not
  recognize the host platform correctly.
  64bit:
  $ ./startup/EpicsHostArch
  lib/perl/EpicsHostArch.pl: Architecture 'x86_64-msys-thread-multi' not recognized
  32bit:
  Which is not surprising, as the underlying MSYS2 subsystem is the
  same, and the difference is in the environment settings that point to
  the appropriate toolchain.
  64bit:
  $ echo $PATH
  /mingw64/bin:/usr/local/bin:/usr/bin:/bin:/c/Windows/System32:/c/Windows:/c/Windows/System32/Wbem:/c/Windows/System32/WindowsPowerShell/v1.0/:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl
  $ printenv | grep MSYSTEM
  MSYSTEM_CARCH=x86_64
  MSYSTEM_CHOST=x86_64-w64-mingw32
  MSYSTEM_PREFIX=/mingw64
  MSYSTEM=MINGW64
  32bit:
  $ echo $PATH
  /mingw32/bin:/usr/local/bin:/usr/bin:/bin:/c/Windows/System32:/c/Windows:/c/Windows/System32/Wbem:/c/Windows/System32/WindowsPowerShell/v1.0/:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl
  MSYSTEM_CARCH=i686
  MSYSTEM_CHOST=i686-w64-mingw32
  MSYSTEM_PREFIX=/mingw32
  MSYSTEM=MINGW32
  NB: I am impressed by the clarity and simplicity of MSYS2 / MinGW
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1873406/+subscriptions
[Bug 1873406] [NEW] EpicsHostArch script does not detect recent MSYS2/MinGW setups on Windows Ralph Lange via Core-talk
Prev: [Bug 1873406] Re: EpicsHostArch script does not detect recent MSYS2/MinGW setups on Windows Greg Huff via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Next: Build failed: EPICS Base base-7.0-586 AppVeyor via Core-talk
ANJ, 26 Nov 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
