2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: mp+394327 at code.launchpad.net
Date: Thu, 26 Nov 2020 16:26:39 -0000
Is there any posix implementation which does not support PTHREAD_MUTEX_RECURSIVE? That would be systems with _XOPEN_SOURCE < 500, that is Posix 1995.
I mean: do we still need the alternative implementation?
I have 12 different Linux architectures, some quite old, and none uses that compilation path.
If we do, should _XOPEN_SOURCE be the thing to be tested or rather #ifdef PTHREAD_MUTEX_RECURSIVE ?
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/394327
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Heinz Junkes via Core-talk
Prev: [Bug 1873406] Re: EpicsHostArch script does not detect recent MSYS2/MinGW setups on Windows Ralph Lange via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 20 Dec 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
