2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: [Bug 1907077] Re: errRawCopy formats S_dbLib_badField as "Error (512, 512)"
From: Ivo Hanak via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Mon, 07 Dec 2020 12:55:52 -0000
** Description changed:
  Problem:
  errRawCopy formats S_dbLib_badField as "Error (512,512)" while it should format it as "Error (512,11)".
- Cause:
+ Scenario:
+ 1) Create a DB with an LSI and add the following field:
+ field(VAL, "initial value")
+ 2) EPICS will print following error:
+ Can't set "lsiRec.VAL" to "initial value" Error (512,512)
+ Potential Cause:
  Line 135, libcom/src/error/errSymLib.c:
  epicsUInt16 modnum = (statusToDecode >>= 16) & 0xffff;
  Solution:
  Replace 135, libcom/src/error/errSymLib.c with:
  epicsUInt16 modnum = (statusToDecode >> 16) & 0xffff;
  Severity:
  This problem makes troubleshooting EPICS DB issues harder.
  Problem:
  Scenario:
- 1) Create a DB with an LSI and add the following field:
- field(VAL, "initial value")
- 2) EPICS will print following error:
+ 1) Create a DB with the following record:
+ record(lsi, "lsiRec")
+     field(SIZV, "256")
+ 2) While loading the DB, EPICS will print the following error:
  Potential Cause:
  Solution:
  Severity:
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1907077
Title:
Status in EPICS Base:
  New
Bug description:
  Problem:
  Scenario:
      field(SIZV, "256")
  Potential Cause:
  Solution:
  Severity:
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1907077/+subscriptions
[Bug 1907077] [NEW] errRawCopy formats S_dbLib_badField as "Error (512, 512)" Ivo Hanak via Core-talk
Prev: [Bug 1907077] [NEW] errRawCopy formats S_dbLib_badField as "Error (512, 512)" Ivo Hanak via Core-talk
Next: [Bug 1907077] Re: errRawCopy formats S_dbLib_badField as "Error (512, 512)" Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
ANJ, 07 Dec 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
