2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0
From: mdavidsaver via Core-talk <core-talk at aps.anl.gov>
To: mp+394327 at code.launchpad.net
Date: Fri, 18 Dec 2020 17:17:10 -0000
Review: Needs Fixing
I pushed your latest to github for testing.  There are a couple of failures with RTEMS and OSX.
https://github.com/mdavidsaver/epics-base/actions/runs/430893895
I still think it is necessary for the new globalAttrInit() to probe for runtime support of PTHREAD_PRIO_INHERIT.  I've included a sketch of this as a diff comment.
Unless I'm misreading, it looks like only the recursive implementation would have PTHREAD_PRIO_INHERIT set.  So the mutex used internally in osdThread and osdSpin would continue to be non-PI.
Diff comments:
> diff --git a/modules/libcom/src/osi/os/posix/osdMutex.c b/modules/libcom/src/osi/os/posix/osdMutex.c
> index 707ae63..a104229 100644
> --- a/modules/libcom/src/osi/os/posix/osdMutex.c
> +++ b/modules/libcom/src/osi/os/posix/osdMutex.c
> @@ -38,6 +39,53 @@
>          cantProceed((method)); \
> +#if defined(DONT_USE_POSIX_THREAD_PRIORITY_SCHEDULING)
> +#undef _POSIX_THREAD_PRIO_INHERIT
> +#endif
> +/* Global var - pthread_once does not support passing args but it is more efficient
> + * than epicsThreadOnce which always acquires a mutex.
> +static pthread_mutexattr_t globalAttrRecursive;
> +static pthread_once_t      globalAttrInitOnce = PTHREAD_ONCE_INIT;
> +static void globalAttrInit()
> +    int status;
> +    status = pthread_mutexattr_init(&globalAttrRecursive);
> +    checkStatusQuit(status,"pthread_mutexattr_init","globalAttrInit");
> +#if defined _POSIX_THREAD_PRIO_INHERIT
> +    status = pthread_mutexattr_setprotocol(&globalAttrRecursive, PTHREAD_PRIO_INHERIT);
> +    if (errVerbose) checkStatus(status, "pthread_mutexattr_setprotocol(PTHREAD_PRIO_INHERIT)");
> +#endif
> +    status = pthread_mutexattr_settype(&globalAttrRecursive, PTHREAD_MUTEX_RECURSIVE);
> +    checkStatusQuit(status, "pthread_mutexattr_settype(PTHREAD_MUTEX_RECURSIVE)", "globalAttrInit");
What I'd like to see here would look something like.
status = pthread_mutex_init(&temp, &globalAttrRecursive);
if(status == EOPNOTSUPP) {
    pthread_mutexattr_setprotocol(&globalAttrRecursive, PTHREAD_PRIO_NONE);
> +int osdPosixMutexInit (pthread_mutex_t *m, int mutextype)
> +    pthread_mutexattr_t *atts;
> +    int status;
> +    status = pthread_once( &globalAttrInitOnce, globalAttrInit );
> +    checkStatusQuit(status,"pthread_once","epicsPosixMutexAttrGet");
> +    switch (mutextype) {
> +        case PTHREAD_MUTEX_DEFAULT:
> +            atts = NULL;
> +            break;
> +        case PTHREAD_MUTEX_RECURSIVE:
> +            atts = &globalAttrRecursive;
> +            break;
> +        default:
> +            return ENOTSUP;
> +    return pthread_mutex_init(m, atts);
>  static int mutexLock(pthread_mutex_t *id)
>      int status;
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/394327
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
Next: -Werror=implicit-function-declaration by default? Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Next: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 18 Dec 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
