2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: -Werror=implicit-function-declaration by default?
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Sat, 19 Dec 2020 00:16:35 +0000
On Dec 18, 2020, at 11:41 AM, Michael Davidsaver via Core-talk <core-talk at aps.anl.gov> wrote:
I'd like to start treating calls to undeclared functions in C as errors,
at least in CI builds.  This has long been an error in c++, but is only
a warning with C.
No major objections from here.
I can easily add this only for the CI jobs w/ GCC with:
cat <<EOF >> configure/CONFIG_SITE.local
USR_CFLAGS += -Werror-implicit-function-declaration
EOF
Note: the newer -Werror=* syntax was added with GCC 4.2.  As of 8.3
the older flag is still recognized (thank you GCC).
VxWorks 6.8 (gcc 4.1.3) doesn’t list -Werror= as supported but does show Werror-implicit-function-declaration as you say.
My question is whether this should become a default for all builds?
(in WARN_CFLAGS_YES?)
For gcc builds I think yes (so in configure/CONFIG.gnuCommon).
My inclination is yes.  I've certainly never intended to rely on an implicit
declaration, but have occasionally done so unwittingly as a result of
a missing #include.
Ditto, nowadays we shouldn’t have any code using implicits (of any sort).
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: -Werror=implicit-function-declaration by default? Ralph Lange via Core-talk
-Werror=implicit-function-declaration by default? Michael Davidsaver via Core-talk
Prev: Build failed: EPICS Base 3.15 base-3.15-27 AppVeyor via Core-talk
Next: Build failed: EPICS Base 3.15 base-3.15-28 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: -Werror=implicit-function-declaration by default? Michael Davidsaver via Core-talk
Next: Re: -Werror=implicit-function-declaration by default? Ralph Lange via Core-talk
ANJ, 20 Dec 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
