2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0
From: Ben Franksen via Core-talk <core-talk at aps.anl.gov>
To: mp+396197 at code.launchpad.net
Date: Tue, 12 Jan 2021 17:41:00 -0000
This is the first failing test (dbCaLinkTest):
# fetch source.INP into source.BPTR
ok 21 - dbGetLink
ok 22 - nReq (1) == (long)num_min (1)
not ok 23 - array update
# 0 0 != 1
Not sure how to interpret this. My first blind guess is that the spec changed here, because
base now accepts empty (zero size) array requests?
https://code.launchpad.net/~bfrk/epics-base/+git/epics-base/+merge/396197
Your team EPICS Core Developers is requested to review the proposed merge of ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0.
[Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0 Ben Franksen via Core-talk
Prev: Re: [Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0 Ben Franksen via Core-talk
Next: Re: [Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0 Ben Franksen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: [Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0 mdavidsaver via Core-talk
ANJ, 13 Jan 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
