2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0
From: mdavidsaver via Core-talk <core-talk at aps.anl.gov>
To: mp+396197 at code.launchpad.net
Date: Wed, 13 Jan 2021 16:38:32 -0000
FYI. in dbCaLinkTest, the tests in testArrayLink(SNELM, TNELM) are run four times with different combinations of SNELM an TNELM.  It would by helpful to know which combination is failing for you.
This is printed in earlier.  eg. as Andrew shows:
> # Link to a array numeric field
> # TARGET=target CA,FTVL=LONG,SNELM=1,TNELM=1
https://code.launchpad.net/~bfrk/epics-base/+git/epics-base/+merge/396197
Your team EPICS Core Developers is requested to review the proposed merge of ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0.
[Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0 Ben Franksen via Core-talk
Prev: Coding style question IOCFUNCDEF_HAS_USAGE Heinz Junkes via Core-talk
Next: Re: Coding style question IOCFUNCDEF_HAS_USAGE Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0 Ben Franksen via Core-talk
Next: Re: [Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0 Ben Franksen via Core-talk
ANJ, 14 Jan 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
