2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0
From: Ben Franksen via Core-talk <core-talk at aps.anl.gov>
To: mp+396197 at code.launchpad.net
Date: Thu, 14 Jan 2021 10:28:36 -0000
In dbCaLinkTest, the tests that fail are those where we check the resulting array data after a successful dbGetLink, except in one place in testArrayLink where we test after doing a putLink first. These are: the first two calls to checkArray in testArrayLink (but not the third) and the two calls to checkArrayDouble in testreTargetTypeChange. The former function gets called 4 times, so we get 10 failures overall. The failures happen for all combinations of parameters (number of elements in source and target).
I spent yesterday staring at code differences (my changes and what changed in the 7.0 branch in the meantime). So far I couldn't find anything to explain why these tests succeed in my original version but fail now. This isn't easy to debug because of the CA layer in between with event queues and whatnot. So It is hard to guess the exact code path this takes (so I could insert printfs at these points).
https://code.launchpad.net/~bfrk/epics-base/+git/epics-base/+merge/396197
Your team EPICS Core Developers is requested to review the proposed merge of ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0.
[Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0 Ben Franksen via Core-talk
Prev: Build failed in Jenkins: EPICS-3.14 #910 Jenkins EPICS PSI via Core-talk
Next: Re: [Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0 Ben Franksen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0 mdavidsaver via Core-talk
ANJ, 14 Jan 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
