So far, looking at what changed between the current HEAD and the version I originally based my changes on, I have only considered changes under modules/database. I will now also consider the possibility that some changes outside of modules/database e.g. in modules/ca have invalidated my patch.
It is very unfortunate that some of the changes that happened in the meantime are bulk changes to things like copyright header comments because that means almost every file has been touched.
https://code.launchpad.net/~bfrk/epics-base/+git/epics-base/+merge/396197
Your team EPICS Core Developers is requested to review the proposed merge of ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0.
- [Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0 Ben Franksen via Core-talk
Re: [Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0 Ben Franksen via Core-talk
Re: Question about travis-ci Torsten Bögershausen via Core-talk
<2021>
2025
2026
<2021>
2025
2026
