2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0
From: Ben Franksen via Core-talk <core-talk at aps.anl.gov>
To: mp+396197 at code.launchpad.net
Date: Thu, 14 Jan 2021 17:06:39 -0000
I gave up on comparing branches (i.e. finding out why it had worked half a year ago and fails now). Instead I concentrated on debugging the problem. I think I have found the correct fix and updated the github PR.
https://code.launchpad.net/~bfrk/epics-base/+git/epics-base/+merge/396197
Your team EPICS Core Developers is requested to review the proposed merge of ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0.
[Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0 Ben Franksen via Core-talk
Prev: Re: Question about travis-ci Torsten Bögershausen via Core-talk
Next: Re: Question about travis-ci Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0 Ben Franksen via Core-talk
Next: Re: [Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0 Ben Franksen via Core-talk
ANJ, 14 Jan 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
