2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Coding style question IOCFUNCDEF_HAS_USAGE
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Heinz Junkes <junkes at fhi-berlin.mpg.de>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Wed, 13 Jan 2021 16:42:59 +0000
On Jan 13, 2021, at 7:03 AM, Heinz Junkes via Core-talk <core-talk at aps.anl.gov> wrote:
In EPICS 7, a macro IOCFUNCDEF_HAS_USAGE is defined in ioch.h.
Taking that into account, my code looks like this (it's not "pretty") :
static const iocshFuncDef rtshellFuncDef = { “rt”,2, rtshellArgs
#ifdef IOCFUNCDEF_HAS_USAGE
  , “run rtems shell command”
#endif
How do you get it to look nice?
It doesn’t look as bad if you don’t use that huge indentation (personally I dislike that indent style, it gets line-wrapped in emails and any changes to the variable name mean you have to redo the number of spaces in the indentation of all the lines below it). I would probably write it like this:
    “rt”, 2, rtshellArgs
    #endif
You could also define your own macro:
#define IOCSH_USAGE(msg) ,msg
#else
#endif
Then the code becomes:
IOCSH_USAGE(“run rtems shell command”)
- Andrew
Complexity comes for free, simplicity you have to work for.
Coding style question IOCFUNCDEF_HAS_USAGE Heinz Junkes via Core-talk
Prev: Re: [Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0 mdavidsaver via Core-talk
Next: Question about travis-ci Mark Rivers via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Coding style question IOCFUNCDEF_HAS_USAGE Heinz Junkes via Core-talk
ANJ, 13 Jan 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
