2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0
From: mdavidsaver via Core-talk <core-talk at aps.anl.gov>
To: mp+394327 at code.launchpad.net
Date: Tue, 26 Jan 2021 17:07:01 -0000
I think this leaves only the question of osdPosixMutexInit() and PTHREAD_MUTEX_DEFAULT.  As it stands now, the mutexs created through epicsMutex can have PI enabled, but those created elsewhere (eg. osdSpin) will not.
wrt. _GNU_SOURCE I don't think this should be defined in osdMutex.c, or any source file.  This is easily removed later though.  Also, it is my turn to be surprised to see #ifdef _GNU_SOURCE appearing in RTEMS (which uses newlib, not glibc).
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/394327
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Prev: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Jenkins build is back to stable : epics-base-3.15-test #215 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 01 Feb 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
