2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: mp+394327 at code.launchpad.net
Date: Mon, 01 Feb 2021 14:52:18 -0000
> As it stands now, the mutexs created through epicsMutex can have PI enabled, but those created elsewhere (eg. osdSpin) will not.
Oops, you are right. I got confused by Andrew's earlier remark:
> Hmm, according to the online spec (and both manpages I just checked) passing a NULL attribute into pthread_mutex_init() is legal and is equivalent to a default-initialized mutex, so we only actually need to create the recursive one.
Of course, a non-recursive mutex with PI enabled is not a default mutex and we need a mutex attribute for those.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/394327
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Prev: Build failed: EPICS Base 7 base-7.0-137 AppVeyor via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 mdavidsaver via Core-talk
ANJ, 01 Feb 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
