2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 1815864] Re: Assemblies fail to work on Windows
From: Ralph Lange via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Tue, 26 Jan 2021 18:00:06 -0000
It indeed is only happening for some versions of make.
However, I finally found and fixed the issue with dd9f38d7 (3.15) /
40d9a21c (7.0).
** Changed in: epics-base
       Status: New => Fix Committed
** Also affects: epics-base/7.0
   Importance: Medium
     Assignee: Ralph Lange (ralph-lange)
       Status: Fix Committed
** Also affects: epics-base/3.15
   Importance: Undecided
       Status: New
** Changed in: epics-base/3.15
   Importance: Undecided => Medium
     Assignee: (unassigned) => Ralph Lange (ralph-lange)
    Milestone: None => 3.15.9
** Changed in: epics-base/7.0
    Milestone: None => 7.0.5
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1815864
Title:
Status in EPICS Base:
  Fix Committed
Status in EPICS Base 3.15 series:
  Fix Committed
Status in EPICS Base 7.0 series:
  Fix Committed
Bug description:
  Though being configured correctly in the Makefile, assemblies using
  the *_SNIPPETS setting fail to be generated on Windows. (VS 2017, GNU
  Make 4.1)
  Unexpected Make output:
  make[2]: *** No rule to make target 'RCS/../', needed by '../'.  Stop.
  The same Makefile on Linux works smoothly.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1815864/+subscriptions
Prev: Jenkins build is back to stable : epics-base-3.15-test #215 APS Jenkins via Core-talk
Next: Build failed in Jenkins: EPICS-3.15 #263 Jenkins EPICS PSI via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: [Bug 1815864] Re: Assemblies fail to work on Windows Andrew Johnson via Core-talk
ANJ, 28 Feb 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
