2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 1815864] Re: Assemblies fail to work on Windows
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Mon, 01 Mar 2021 04:21:43 -0000
** Changed in: epics-base/7.0
       Status: Fix Committed => Fix Released
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1815864
Title:
Status in EPICS Base:
  Fix Released
Status in EPICS Base 3.15 series:
  Fix Committed
Status in EPICS Base 7.0 series:
  Fix Released
Bug description:
  Though being configured correctly in the Makefile, assemblies using
  the *_SNIPPETS setting fail to be generated on Windows. (VS 2017, GNU
  Make 4.1)
  Unexpected Make output:
  make[2]: *** No rule to make target 'RCS/../', needed by '../'.  Stop.
  The same Makefile on Linux works smoothly.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1815864/+subscriptions
Prev: [Bug 1242919] Re: caget of an empty waveform record returns 2.50321e-308 in 1st element Andrew Johnson via Core-talk
Next: [Bug 1899697] Re: PHAS is not always respected when SCAN=Event Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: [Bug 1815864] Re: Assemblies fail to work on Windows Ralph Lange via Core-talk
Next: [Bug 1815864] Re: Assemblies fail to work on Windows Andrew Johnson via Core-talk
ANJ, 27 Jun 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
