2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Unit tests on Windows DLL internals
From: Mark Rivers via Core-talk <core-talk at aps.anl.gov>
To: Ralph Lange <ralph.lange at gmx.de>
Cc: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Wed, 27 Jan 2021 11:57:37 +0000
> (No such problem on Linux where all functions inside the shared library are visible.)
That is true by default, but GCC >= 4 has __attribute__ ((visibility ("hidden"))) which will also hide classes on Linux.
This article makes the argument for why it is a good idea to use it:
https://gcc.gnu.org/wiki/Visibility
From: Core-talk <core-talk-bounces at aps.anl.gov> on behalf of Ralph Lange via Core-talk <core-talk at aps.anl.gov>
Sent: Wednesday, January 27, 2021 5:01 AM
To: EPICS Core Talk
Subject: Unit tests on Windows DLL internals
Question about developing on Windows:
How do you manage unit testing of internal classes in DLLs?
Internal classes (that are not DLL exported) are by design not visible through the DLL interface, which means linking a unit test against the DLL won't allow it to access the internal APIs it is supposed to test.
I know I can work around by linking the needed objects directly into the test executable. Is there any preferable or better solution?
~Ralph
Unit tests on Windows DLL internals Ralph Lange via Core-talk
Prev: Re: A general question about convert e.g. in longout record drvh, drvl handling Heinz Junkes via Core-talk
Next: Re: Unit tests on Windows DLL internals Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Unit tests on Windows DLL internals Ralph Lange via Core-talk
ANJ, 27 Jan 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
