Review: Approve
... __GLIBC_PREREQ
Ah, sorry I didn't catch this. There is a difference in how CPP treats undefined "variable" vs. "function" macros. eg. an undefined __GNUC__ will silently expand to zero. An undefined __GLIBC_PREREQ() is an error.
What you have is fine, and no further change is needed. So I think this change is now ready to merge.
I will note that this could also be expressed using the VERSION_INT() macro from epicsVersion.h as
> #ifdef __GLIBC__
> #define GLIBC_VERSION VERSION_INT(__GLIBC__, __GLIBC_MINOR__, 0, 0)
> #endif
and then
> #if GLIBC_VERSION >= VERSION_INT(2,4,0,0)
This works since an undefined GLIBC_VERSION is treated as a zero.
> ... The CI environments should ...
This is currently being controlled by '.github/workflows/ci-scripts-build.yml'. As a first pass, I should be sufficient to apply 'sudo' to the following line.
> run: python .ci/cue.py test
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/394327
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
<2021>
2025
2026
<2021>
2025
2026
