See <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/321/display/redirect?page=changes>
Changes:
[jeonghan.lee] add dawrin-aarch64 (arm64) Host Arch
[jeonghan.lee] fixed a typo in CONFIG.Common.darwin-aarch64
[mdavidsaver] dbConstAddLink bounds check dbrType
[...truncated 1.17 MB...]
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/default/osdThreadHooks.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/vxWorks/osdMutex.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/vxWorks/osdSpin.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/vxWorks/osdEvent.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -DBUILD_TIME=1613849512 -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/vxWorks/osdTime.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/vxWorks/osdMonotonic.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/vxWorks/osdProcess.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/default/osdNetIntf.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/vxWorks/osdMessageQueue.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/default/osdgetexec.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/devLibVME.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/vxWorks/devLibVMEOSD.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/epicsStackTrace.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/default/osdBackTrace.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/default/osdFindAddr.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../pool/poolJob.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../pool/threadPool.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../ring/epicsRingPointer.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../ring/epicsRingBytes.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../taskwd/taskwd.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../timer/epicsTimer.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../timer/timer.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../timer/timerQueue.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../timer/timerQueueActive.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../timer/timerQueueActiveMgr.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../timer/timerQueuePassive.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../yajl/yajl.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../yajl/yajl_alloc.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../yajl/yajl_buf.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../yajl/yajl_encode.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../yajl/yajl_gen.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../yajl/yajl_lex.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../yajl/yajl_parser.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/osiNTPTime.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/vxWorks/tz2timezone.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/vxWorks/atReboot.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/vxWorks/epicsDynLink.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/vxWorks/veclist.c
../osi/os/vxWorks/veclist.c: In function 'veclist':
../osi/os/vxWorks/veclist.c:76: warning: 'symFindByValue' is deprecated (declared at /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/symLib.h:119)
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/vxWorks/logMsgToErrlog.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/vxWorks/strtoll.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/vxWorks/strtoull.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/arppc -rc libCom.a asLib.o asTrapWrite.o bucketLib.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsSingletonMutex.o dbmf.o ellLib.o ellSort.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o initHooks.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o alarmString.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsAtomicOSD.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osdSockUnsentCount.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdThreadExtra.o osdThreadHooks.o osdMutex.o osdSpin.o osdEvent.o osdTime.o osdMonotonic.o osdProcess.o osdNetIntf.o osdMessageQueue.o osdgetexec.o devLibVME.o devLibVMEOSD.o epicsStackTrace.o osdBackTrace.o osdFindAddr.o poolJob.o threadPool.o epicsRingPointer.o epicsRingBytes.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o yajl.o yajl_alloc.o yajl_buf.o yajl_encode.o yajl_gen.o yajl_lex.o yajl_parser.o osiNTPTime.o tz2timezone.o atReboot.o epicsDynLink.o veclist.o logMsgToErrlog.o strtoll.o strtoull.o
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ranlibppc libCom.a
Installing library ../../../../lib/V67-ppc604/libCom.a
Installing created executable ../../../../bin/V67-ppc604/vxComLibrary.o
mkdir ../../../../bin/V67-ppc604
make[4]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/modules/libcom/src/O.V67-ppc604'>
make -C O.V63-ppc603 -f ../Makefile TOP=../../../.. \
T_A=V63-ppc603 install
make[4]: Entering directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/modules/libcom/src/O.V63-ppc603'>
Expanding ../libComVersion.h@ to ../O.Common/libComVersion.h
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/expandVars.pl> -t ../../../.. -D INSTALL_BIN=<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/V63-ppc603> -DEPICS_LIBCOM_MAJOR_VERSION="3" -DEPICS_LIBCOM_MINOR_VERSION="18" -DEPICS_LIBCOM_MAINTENANCE_VERSION="2" -DEPICS_LIBCOM_DEVELOPMENT_FLAG="1" ../libComVersion.h@ libComVersion.h
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF strtoull.d ../osi/os/vxWorks/strtoull.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF strtoll.d ../osi/os/vxWorks/strtoll.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF logMsgToErrlog.d ../osi/os/vxWorks/logMsgToErrlog.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF veclist.d ../osi/os/vxWorks/veclist.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsDynLink.d ../osi/os/vxWorks/epicsDynLink.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF atReboot.d ../osi/os/vxWorks/atReboot.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF tz2timezone.d ../osi/os/vxWorks/tz2timezone.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osiNTPTime.d ../osi/osiNTPTime.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF yajl_parser.d ../yajl/yajl_parser.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF yajl_lex.d ../yajl/yajl_lex.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF yajl_gen.d ../yajl/yajl_gen.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF yajl_encode.d ../yajl/yajl_encode.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF yajl_buf.d ../yajl/yajl_buf.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF yajl_alloc.d ../yajl/yajl_alloc.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF yajl.d ../yajl/yajl.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF timerQueuePassive.d ../timer/timerQueuePassive.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF timerQueueActiveMgr.d ../timer/timerQueueActiveMgr.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF timerQueueActive.d ../timer/timerQueueActive.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF timerQueue.d ../timer/timerQueue.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF timer.d ../timer/timer.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsTimer.d ../timer/epicsTimer.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF taskwd.d ../taskwd/taskwd.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsRingBytes.d ../ring/epicsRingBytes.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsRingPointer.d ../ring/epicsRingPointer.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF threadPool.d ../pool/threadPool.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF poolJob.d ../pool/poolJob.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdFindAddr.d ../osi/os/default/osdFindAddr.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdBackTrace.d ../osi/os/default/osdBackTrace.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsStackTrace.d ../osi/epicsStackTrace.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF devLibVMEOSD.d ../osi/os/vxWorks/devLibVMEOSD.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF devLibVME.d ../osi/devLibVME.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdgetexec.d ../osi/os/default/osdgetexec.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdMessageQueue.d ../osi/os/vxWorks/osdMessageQueue.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdNetIntf.d ../osi/os/default/osdNetIntf.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdProcess.d ../osi/os/vxWorks/osdProcess.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdMonotonic.d ../osi/os/vxWorks/osdMonotonic.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdTime.d ../osi/os/vxWorks/osdTime.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdEvent.d ../osi/os/vxWorks/osdEvent.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdSpin.d ../osi/os/vxWorks/osdSpin.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdMutex.d ../osi/os/vxWorks/osdMutex.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdThreadHooks.d ../osi/os/default/osdThreadHooks.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdThreadExtra.d ../osi/os/vxWorks/osdThreadExtra.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdThread.d ../osi/os/vxWorks/osdThread.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdStdio.d ../osi/os/vxWorks/osdStdio.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsStdio.d ../osi/epicsStdio.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsTempFile.d ../osi/os/posix/epicsTempFile.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_LEDLIB -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsReadline.d ../osi/epicsReadline.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdEnv.d ../osi/os/vxWorks/osdEnv.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdSignal.d ../osi/os/vxWorks/osdSignal.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdPoolStatus.d ../osi/os/vxWorks/osdPoolStatus.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdInterrupt.d ../osi/os/vxWorks/osdInterrupt.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdFindSymbol.d ../osi/os/vxWorks/osdFindSymbol.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdAssert.d ../osi/os/default/osdAssert.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsSocketConvertErrnoToString.d ../osi/os/default/epicsSocketConvertErrnoToString.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF systemCallIntMech.d ../osi/os/posix/systemCallIntMech.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osiSock.d ../osi/osiSock.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdSockUnsentCount.d ../osi/os/default/osdSockUnsentCount.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdSockAddrReuse.d ../osi/os/default/osdSockAddrReuse.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdSock.d ../osi/os/vxWorks/osdSock.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osiClockTime.d ../osi/osiClockTime.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsGeneralTime.d ../osi/epicsGeneralTime.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsAtomicOSD.d ../osi/os/vxWorks/epicsAtomicOSD.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsMath.d ../osi/epicsMath.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsMessageQueue.d ../osi/epicsMessageQueue.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsTime.d ../osi/epicsTime.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsEvent.d ../osi/epicsEvent.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsMutex.d ../osi/epicsMutex.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsThread.d ../osi/epicsThread.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsUnitTest.d ../misc/epicsUnitTest.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF ipAddrToAsciiAsynchronous.d ../misc/ipAddrToAsciiAsynchronous.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF truncateFile.d ../misc/truncateFile.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsString.d ../misc/epicsString.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsStdlib.d ../misc/epicsStdlib.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsExit.d ../misc/epicsExit.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsConvert.d ../misc/epicsConvert.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF cantProceed.d ../misc/cantProceed.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF adjustment.d ../misc/adjustment.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF aToIPAddr.d ../misc/aToIPAddr.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF alarmString.d ../misc/alarmString.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF macUtil.d ../macLib/macUtil.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF macEnv.d ../macLib/macEnv.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF macCore.d ../macLib/macCore.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF logClient.d ../log/logClient.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF iocLog.d ../log/iocLog.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF libComRegister.d ../iocsh/libComRegister.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF registry.d ../iocsh/registry.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF initHooks.d ../iocsh/initHooks.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF iocsh.d ../iocsh/iocsh.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF gpHashLib.d ../gpHash/gpHashLib.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF freeListLib.d ../freeList/freeListLib.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF fdManager.d ../fdmgr/fdManager.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF fdmgr.d ../fdmgr/fdmgr.cpp
perl -CSD ../error/makeStatTbl.pl ../osi/devLib.h ../osi/epicsTime.h ../as/asLib.h ../misc/epicsStdlib.h ../pool/epicsThreadPool.h ../error/errMdef.h ../../../../modules/database/src/ioc/db/dbAccessDefs.h ../../../../modules/database/src/ioc/dbStatic/dbStaticLib.h
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF errSymTbl.d errSymTbl.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF errSymLib.d ../error/errSymLib.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF errlog.d ../error/errlog.c
perl -CSD ../../../../bin/RHEL7-x86_64/bldEnvData.pl -t V63-ppc603 \
-c gcc -s vxWorks ../../../../configure
Generating envData.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF envData.d envData.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF envSubr.d ../env/envSubr.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF ellSort.d ../ellLib/ellSort.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF ellLib.d ../ellLib/ellLib.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF dbmf.d ../dbmf/dbmf.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsSingletonMutex.d ../cxxTemplates/epicsSingletonMutex.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF resourceLib.d ../cxxTemplates/resourceLib.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF cvtFast.d ../cvtFast/cvtFast.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF calcPerform.d ../calc/calcPerform.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF postfix.d ../calc/postfix.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF bucketLib.d ../bucketLib/bucketLib.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF asTrapWrite.d ../as/asTrapWrite.c
<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/e_flex> -S../../../../include/flex.skel.static -8 -I -oasLib_lex.c ../as/asLib_lex.l
<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/antelope> -basLib ../as/asLib.y
mv asLib.tab.c asLib.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF asLib.d asLib.c
make[4]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/modules/libcom/src/O.V63-ppc603'>
make[4]: Entering directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/modules/libcom/src/O.V63-ppc603'>
Expanding ../libComVersion.h@ to ../O.Common/libComVersion.h
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/expandVars.pl> -t ../../../.. -D INSTALL_BIN=<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/V63-ppc603> -DEPICS_LIBCOM_MAJOR_VERSION="3" -DEPICS_LIBCOM_MINOR_VERSION="18" -DEPICS_LIBCOM_MAINTENANCE_VERSION="2" -DEPICS_LIBCOM_DEVELOPMENT_FLAG="1" ../libComVersion.h@ libComVersion.h
Installing generated generic include file ../../../../include/libComVersion.h
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/os/vxWorks/vxComLibrary.c
../osi/os/vxWorks/vxComLibrary.c: In function `vxComLibrary':
../osi/os/vxWorks/vxComLibrary.c:26: warning: `symFindByNameEPICS' is deprecated (declared at ../osi/os/vxWorks/epicsDynLink.h:31)
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c asLib.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../as/asTrapWrite.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../bucketLib/bucketLib.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../calc/postfix.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../calc/calcPerform.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../cvtFast/cvtFast.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../cxxTemplates/resourceLib.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../cxxTemplates/epicsSingletonMutex.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../dbmf/dbmf.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../ellLib/ellLib.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../ellLib/ellSort.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../env/envSubr.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c envData.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../error/errlog.c
../error/errlog.c: In function `errlogPrintf':
../error/errlog.c:110: warning: 'nchar' might be used uninitialized in this function
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../error/errSymLib.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c errSymTbl.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../fdmgr/fdmgr.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../fdmgr/fdManager.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../freeList/freeListLib.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../gpHash/gpHashLib.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../iocsh/iocsh.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../iocsh/initHooks.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../iocsh/registry.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../iocsh/libComRegister.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../log/iocLog.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../log/logClient.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../macLib/macCore.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../macLib/macEnv.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../macLib/macUtil.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../misc/alarmString.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../misc/aToIPAddr.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../misc/adjustment.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../misc/cantProceed.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../misc/epicsConvert.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../misc/epicsExit.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../misc/epicsStdlib.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../misc/epicsString.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../misc/truncateFile.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../misc/ipAddrToAsciiAsynchronous.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../misc/epicsUnitTest.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/epicsThread.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/epicsMutex.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/epicsEvent.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/epicsTime.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/epicsMessageQueue.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/epicsMath.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/os/vxWorks/epicsAtomicOSD.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/epicsGeneralTime.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/osiClockTime.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/os/vxWorks/osdSock.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/os/default/osdSockAddrReuse.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/os/default/osdSockUnsentCount.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/osiSock.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/os/posix/systemCallIntMech.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/os/default/epicsSocketConvertErrnoToString.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/os/default/osdAssert.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -DBUILDING_libCom_API -O2 -Wall -Werror-implicit-function-declaration -mcpu=603 -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/os/vxWorks/osdFindSymbol.c
../osi/os/vxWorks/osdFindSymbol.c: In function `epicsLoadLibrary':
../osi/os/vxWorks/osdFindSymbol.c:49: error: implicit declaration of function `close'
make[4]: *** [osdFindSymbol.o] Error 1
make[3]: *** [install.V63-ppc603] Error 2
make[3]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/modules/libcom/src'>
make[2]: *** [src.install] Error 2
make[2]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/modules/libcom'>
make[1]: *** [libcom.install] Error 2
make[1]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/modules'>
make: *** [modules.install] Error 2
Build step 'Execute shell' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
- Build failed in Jenkins: EPICS-7 #322 Jenkins EPICS PSI via Core-talk
- Build failed in Jenkins: EPICS-7 #320 Jenkins EPICS PSI via Core-talk
Build failed in Jenkins: epics-example-win64 #606 APS Jenkins via Core-talk
[Merge] ~freddie-akeroyd/epics-base:fix_win32_monotonic_time into epics-base:7.0 noreply--- via Core-talk
<2021>
2025
2026
<2021>
2025
2026
