2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: EPICS-7 #322
From: Jenkins EPICS PSI via Core-talk <core-talk at aps.anl.gov>
To: <dirk.zimoch at psi.ch>, <core-talk at aps.anl.gov>
Date: Sun, 21 Feb 2021 20:32:22 +0100
See <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/322/display/redirect?page=changes>
Changes:
[freddie.akeroyd] * Fix and enable usage of QueryPerformanceCounter() * Use
[freddie.akeroyd] Print warning if using GetTickCount()
[freddie.akeroyd] Remove use of GetTickCount() - only use performance counter
[freddie.akeroyd] Call cantProceed() if performance counter is unavailable
[freddie.akeroyd] Make returned value relative to IOC boot time to improve accuracy
[freddie.akeroyd] Use native Windows type for perfCounterOffset
[anj] Windows: Move cxx warning flag to the right CONFIG file
[anj] Fix MS compiler issue that I introduced into Freddie's code
[...truncated 1.17 MB...]
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/default/osdThreadHooks.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/vxWorks/osdMutex.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/vxWorks/osdSpin.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/vxWorks/osdEvent.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall    -DBUILD_TIME=1613935926  -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/vxWorks/osdTime.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/vxWorks/osdMonotonic.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/vxWorks/osdProcess.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/default/osdNetIntf.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/vxWorks/osdMessageQueue.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/default/osdgetexec.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/devLibVME.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/vxWorks/devLibVMEOSD.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/epicsStackTrace.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/default/osdBackTrace.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/default/osdFindAddr.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../pool/poolJob.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../pool/threadPool.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../ring/epicsRingPointer.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../ring/epicsRingBytes.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../taskwd/taskwd.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../timer/epicsTimer.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../timer/timer.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../timer/timerQueue.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../timer/timerQueueActive.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../timer/timerQueueActiveMgr.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../timer/timerQueuePassive.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../yajl/yajl.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../yajl/yajl_alloc.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../yajl/yajl_buf.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../yajl/yajl_encode.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../yajl/yajl_gen.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../yajl/yajl_lex.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../yajl/yajl_parser.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/osiNTPTime.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/vxWorks/tz2timezone.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/vxWorks/atReboot.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/vxWorks/epicsDynLink.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/vxWorks/veclist.c
../osi/os/vxWorks/veclist.c: In function 'veclist':
../osi/os/vxWorks/veclist.c:76: warning: 'symFindByValue' is deprecated (declared at /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/symLib.h:119)
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/vxWorks/logMsgToErrlog.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/vxWorks/strtoll.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../osi/os/vxWorks/strtoull.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/arppc -rc    libCom.a    asLib.o asTrapWrite.o bucketLib.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsSingletonMutex.o dbmf.o ellLib.o ellSort.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o initHooks.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o alarmString.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsAtomicOSD.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osdSockUnsentCount.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdThreadExtra.o osdThreadHooks.o osdMutex.o osdSpin.o osdEvent.o osdTime.o osdMonotonic.o osdProcess.o osdNetIntf.o osdMessageQueue.o osdgetexec.o devLibVME.o devLibVMEOSD.o epicsStackTrace.o osdBackTrace.o osdFindAddr.o poolJob.o threadPool.o epicsRingPointer.o epicsRingBytes.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o yajl.o yajl_alloc.o yajl_buf.o yajl_encode.o yajl_gen.o yajl_lex.o yajl_parser.o osiNTPTime.o tz2timezone.o atReboot.o epicsDynLink.o veclist.o logMsgToErrlog.o strtoll.o strtoull.o
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ranlibppc libCom.a
Installing library ../../../../lib/V67-ppc604/libCom.a
Installing created executable ../../../../bin/V67-ppc604/vxComLibrary.o
mkdir ../../../../bin/V67-ppc604
make[4]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/modules/libcom/src/O.V67-ppc604'>
make -C O.V63-ppc603 -f ../Makefile TOP=../../../.. \
    T_A=V63-ppc603 install
make[4]: Entering directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/modules/libcom/src/O.V63-ppc603'>
Expanding ../libComVersion.h@ to ../O.Common/libComVersion.h
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/expandVars.pl> -t ../../../.. -D INSTALL_BIN=<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/V63-ppc603>  -DEPICS_LIBCOM_MAJOR_VERSION="3"  -DEPICS_LIBCOM_MINOR_VERSION="18"  -DEPICS_LIBCOM_MAINTENANCE_VERSION="2"  -DEPICS_LIBCOM_DEVELOPMENT_FLAG="1"  ../libComVersion.h@ libComVersion.h
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF strtoull.d  ../osi/os/vxWorks/strtoull.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF strtoll.d  ../osi/os/vxWorks/strtoll.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF logMsgToErrlog.d  ../osi/os/vxWorks/logMsgToErrlog.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF veclist.d  ../osi/os/vxWorks/veclist.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsDynLink.d  ../osi/os/vxWorks/epicsDynLink.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF atReboot.d  ../osi/os/vxWorks/atReboot.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF tz2timezone.d  ../osi/os/vxWorks/tz2timezone.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osiNTPTime.d  ../osi/osiNTPTime.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF yajl_parser.d  ../yajl/yajl_parser.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF yajl_lex.d  ../yajl/yajl_lex.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF yajl_gen.d  ../yajl/yajl_gen.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF yajl_encode.d  ../yajl/yajl_encode.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF yajl_buf.d  ../yajl/yajl_buf.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF yajl_alloc.d  ../yajl/yajl_alloc.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF yajl.d  ../yajl/yajl.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF timerQueuePassive.d  ../timer/timerQueuePassive.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF timerQueueActiveMgr.d  ../timer/timerQueueActiveMgr.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF timerQueueActive.d  ../timer/timerQueueActive.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF timerQueue.d  ../timer/timerQueue.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF timer.d  ../timer/timer.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsTimer.d  ../timer/epicsTimer.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF taskwd.d  ../taskwd/taskwd.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsRingBytes.d  ../ring/epicsRingBytes.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsRingPointer.d  ../ring/epicsRingPointer.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF threadPool.d  ../pool/threadPool.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF poolJob.d  ../pool/poolJob.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdFindAddr.d  ../osi/os/default/osdFindAddr.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdBackTrace.d  ../osi/os/default/osdBackTrace.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsStackTrace.d  ../osi/epicsStackTrace.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF devLibVMEOSD.d  ../osi/os/vxWorks/devLibVMEOSD.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF devLibVME.d  ../osi/devLibVME.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdgetexec.d  ../osi/os/default/osdgetexec.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdMessageQueue.d  ../osi/os/vxWorks/osdMessageQueue.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdNetIntf.d  ../osi/os/default/osdNetIntf.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdProcess.d  ../osi/os/vxWorks/osdProcess.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdMonotonic.d  ../osi/os/vxWorks/osdMonotonic.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdTime.d  ../osi/os/vxWorks/osdTime.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdEvent.d  ../osi/os/vxWorks/osdEvent.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdSpin.d  ../osi/os/vxWorks/osdSpin.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdMutex.d  ../osi/os/vxWorks/osdMutex.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdThreadHooks.d  ../osi/os/default/osdThreadHooks.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdThreadExtra.d  ../osi/os/vxWorks/osdThreadExtra.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdThread.d  ../osi/os/vxWorks/osdThread.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdStdio.d  ../osi/os/vxWorks/osdStdio.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsStdio.d  ../osi/epicsStdio.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsTempFile.d  ../osi/os/posix/epicsTempFile.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration   -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_LEDLIB   -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsReadline.d  ../osi/epicsReadline.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdEnv.d  ../osi/os/vxWorks/osdEnv.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdSignal.d  ../osi/os/vxWorks/osdSignal.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdPoolStatus.d  ../osi/os/vxWorks/osdPoolStatus.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdInterrupt.d  ../osi/os/vxWorks/osdInterrupt.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdFindSymbol.d  ../osi/os/vxWorks/osdFindSymbol.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdAssert.d  ../osi/os/default/osdAssert.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsSocketConvertErrnoToString.d  ../osi/os/default/epicsSocketConvertErrnoToString.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF systemCallIntMech.d  ../osi/os/posix/systemCallIntMech.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osiSock.d  ../osi/osiSock.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdSockUnsentCount.d  ../osi/os/default/osdSockUnsentCount.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdSockAddrReuse.d  ../osi/os/default/osdSockAddrReuse.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osdSock.d  ../osi/os/vxWorks/osdSock.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF osiClockTime.d  ../osi/osiClockTime.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsGeneralTime.d  ../osi/epicsGeneralTime.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsAtomicOSD.d  ../osi/os/vxWorks/epicsAtomicOSD.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsMath.d  ../osi/epicsMath.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsMessageQueue.d  ../osi/epicsMessageQueue.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsTime.d  ../osi/epicsTime.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsEvent.d  ../osi/epicsEvent.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsMutex.d  ../osi/epicsMutex.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsThread.d  ../osi/epicsThread.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsUnitTest.d  ../misc/epicsUnitTest.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF ipAddrToAsciiAsynchronous.d  ../misc/ipAddrToAsciiAsynchronous.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF truncateFile.d  ../misc/truncateFile.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsString.d  ../misc/epicsString.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsStdlib.d  ../misc/epicsStdlib.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsExit.d  ../misc/epicsExit.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsConvert.d  ../misc/epicsConvert.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF cantProceed.d  ../misc/cantProceed.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF adjustment.d  ../misc/adjustment.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF aToIPAddr.d  ../misc/aToIPAddr.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF alarmString.d  ../misc/alarmString.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF macUtil.d  ../macLib/macUtil.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF macEnv.d  ../macLib/macEnv.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF macCore.d  ../macLib/macCore.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF logClient.d  ../log/logClient.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF iocLog.d  ../log/iocLog.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF libComRegister.d  ../iocsh/libComRegister.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF registry.d  ../iocsh/registry.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF initHooks.d  ../iocsh/initHooks.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF iocsh.d  ../iocsh/iocsh.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF gpHashLib.d  ../gpHash/gpHashLib.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF freeListLib.d  ../freeList/freeListLib.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF fdManager.d  ../fdmgr/fdManager.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF fdmgr.d  ../fdmgr/fdmgr.cpp
perl -CSD ../error/makeStatTbl.pl  ../osi/devLib.h ../osi/epicsTime.h ../as/asLib.h ../misc/epicsStdlib.h ../pool/epicsThreadPool.h ../error/errMdef.h ../../../../modules/database/src/ioc/db/dbAccessDefs.h ../../../../modules/database/src/ioc/dbStatic/dbStaticLib.h
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF errSymTbl.d  errSymTbl.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF errSymLib.d  ../error/errSymLib.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF errlog.d  ../error/errlog.c
perl -CSD ../../../../bin/RHEL7-x86_64/bldEnvData.pl  -t V63-ppc603 \
	-c gcc -s vxWorks ../../../../configure
Generating envData.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF envData.d  envData.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF envSubr.d  ../env/envSubr.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF ellSort.d  ../ellLib/ellSort.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF ellLib.d  ../ellLib/ellLib.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF dbmf.d  ../dbmf/dbmf.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF epicsSingletonMutex.d  ../cxxTemplates/epicsSingletonMutex.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF resourceLib.d  ../cxxTemplates/resourceLib.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF cvtFast.d  ../cvtFast/cvtFast.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF calcPerform.d  ../calc/calcPerform.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF postfix.d  ../calc/postfix.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF bucketLib.d  ../bucketLib/bucketLib.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF asTrapWrite.d  ../as/asTrapWrite.c
<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/e_flex> -S../../../../include/flex.skel.static -8 -I -oasLib_lex.c ../as/asLib_lex.l
<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/antelope> -basLib  ../as/asLib.y
mv asLib.tab.c asLib.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM -MF asLib.d  asLib.c
make[4]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/modules/libcom/src/O.V63-ppc603'>
make[4]: Entering directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/modules/libcom/src/O.V63-ppc603'>
Expanding ../libComVersion.h@ to ../O.Common/libComVersion.h
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/expandVars.pl> -t ../../../.. -D INSTALL_BIN=<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/V63-ppc603>  -DEPICS_LIBCOM_MAJOR_VERSION="3"  -DEPICS_LIBCOM_MINOR_VERSION="18"  -DEPICS_LIBCOM_MAINTENANCE_VERSION="2"  -DEPICS_LIBCOM_DEVELOPMENT_FLAG="1"  ../libComVersion.h@ libComVersion.h
Installing generated generic include file ../../../../include/libComVersion.h
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/os/vxWorks/vxComLibrary.c
../osi/os/vxWorks/vxComLibrary.c: In function `vxComLibrary':
../osi/os/vxWorks/vxComLibrary.c:26: warning: `symFindByNameEPICS' is deprecated (declared at ../osi/os/vxWorks/epicsDynLink.h:31)
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c asLib.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../as/asTrapWrite.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../bucketLib/bucketLib.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../calc/postfix.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../calc/calcPerform.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../cvtFast/cvtFast.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../cxxTemplates/resourceLib.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../cxxTemplates/epicsSingletonMutex.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../dbmf/dbmf.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../ellLib/ellLib.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../ellLib/ellSort.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../env/envSubr.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c envData.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../error/errlog.c
../error/errlog.c: In function `errlogPrintf':
../error/errlog.c:110: warning: 'nchar' might be used uninitialized in this function
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../error/errSymLib.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c errSymTbl.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../fdmgr/fdmgr.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../fdmgr/fdManager.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../freeList/freeListLib.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../gpHash/gpHashLib.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../iocsh/iocsh.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../iocsh/initHooks.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../iocsh/registry.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../iocsh/libComRegister.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../log/iocLog.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../log/logClient.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../macLib/macCore.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../macLib/macEnv.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../macLib/macUtil.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../misc/alarmString.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../misc/aToIPAddr.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../misc/adjustment.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../misc/cantProceed.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../misc/epicsConvert.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../misc/epicsExit.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../misc/epicsStdlib.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../misc/epicsString.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../misc/truncateFile.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../misc/ipAddrToAsciiAsynchronous.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../misc/epicsUnitTest.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/epicsThread.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/epicsMutex.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/epicsEvent.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/epicsTime.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/epicsMessageQueue.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/epicsMath.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/os/vxWorks/epicsAtomicOSD.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/epicsGeneralTime.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/osiClockTime.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/os/vxWorks/osdSock.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/os/default/osdSockAddrReuse.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/os/default/osdSockUnsentCount.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/osiSock.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/os/posix/systemCallIntMech.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/os/default/epicsSocketConvertErrnoToString.cpp
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/os/default/osdAssert.c
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc            -DCPU=PPC603    -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mcpu=603 -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -c ../osi/os/vxWorks/osdFindSymbol.c
../osi/os/vxWorks/osdFindSymbol.c: In function `epicsLoadLibrary':
../osi/os/vxWorks/osdFindSymbol.c:49: error: implicit declaration of function `close'
make[4]: *** [osdFindSymbol.o] Error 1
make[3]: *** [install.V63-ppc603] Error 2
make[3]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/modules/libcom/src'>
make[2]: *** [src.install] Error 2
make[2]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/modules/libcom'>
make[1]: *** [libcom.install] Error 2
make[1]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/modules'>
make: *** [modules.install] Error 2
Build step 'Execute shell' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
Build failed in Jenkins: EPICS-7 #323 Jenkins EPICS PSI via Core-talk
Build failed in Jenkins: EPICS-7 #321 Jenkins EPICS PSI via Core-talk
Prev: Build failed in Jenkins: epics-example-win64 #608 APS Jenkins via Core-talk
Next: Build failed in Jenkins: epics-example-win64 #609 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Build failed in Jenkins: EPICS-7 #321 Jenkins EPICS PSI via Core-talk
Next: Build failed in Jenkins: EPICS-7 #323 Jenkins EPICS PSI via Core-talk
ANJ, 22 Feb 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
