** Changed in: epics-base/7.0
Status: In Progress => Fix Committed
Milestone: None => 7.0.5
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1714455
Title:
change request: filters should allow 'relaxed JSON'
Status in EPICS Base:
Fix Committed
Status in EPICS Base 7.0 series:
Fix Committed
Bug description:
For the sake of easier typing, shorter channel names, improved
readability and consistency, CA filters should allow the same
simplified (or 'relaxed') JSON syntax as the 3.16 DB parser already
allows, that is skipping the quotes around field names.
For example instead of
caget 'test:channel.{"arr":{"s":2,"i":2,"e":8}}'
allow
caget test:channel.{arr:{s:2,i:2,e:8}}
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1714455/+subscriptions
Build failed in Jenkins: 3.15-example-win64s #228 APS Jenkins via Core-talk
Build failed in Jenkins: epics-example-win64 #616 APS Jenkins via Core-talk
<2021>
2025
2026
Build failed: EPICS Base 7 base-7.0-171 AppVeyor via Core-talk
[Bug 1714455] Re: change request: filters should allow 'relaxed JSON' Andrew Johnson via Core-talk
<2021>
2025
2026
