2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 1714455] Re: change request: filters should allow 'relaxed JSON'
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Mon, 01 Mar 2021 04:22:27 -0000
** Changed in: epics-base/7.0
       Status: Fix Committed => Fix Released
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1714455
Title:
Status in EPICS Base:
  Fix Released
Status in EPICS Base 7.0 series:
  Fix Released
Bug description:
  For the sake of easier typing, shorter channel names, improved
  readability and consistency, CA filters should allow the same
  simplified (or 'relaxed') JSON syntax as the 3.16 DB parser already
  allows, that is skipping the quotes around field names.
  For example instead of
  caget 'test:channel.{"arr":{"s":2,"i":2,"e":8}}'
  allow
  caget test:channel.{arr:{s:2,i:2,e:8}}
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1714455/+subscriptions
Prev: [Bug 1910266] Re: FTBFS on FreeBSD 12 Andrew Johnson via Core-talk
Next: [Bug 1881563] Re: Empty arrays have undefined behavior Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: [Bug 1714455] Re: change request: filters should allow 'relaxed JSON' Andrew Johnson via Core-talk
Next: epics-pva2pva-linux32 - Build # 213 - Unstable! APS Jenkins via Core-talk
ANJ, 28 Feb 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
