Build and test the EPICS v4 pva2pva module on 32-bit Linux Triggered by: epics-pvAccess-linux32 Build URL: https://jenkins.aps.anl.gov/job/epics-pva2pva-linux32/213/ This job built successfully, but has failing tests. Test results:
testmon.tap .. ok
All tests successful.
Files=1, Tests=79, 0 wallclock secs ( 0.07 usr + 0.01 sys = 0.08 CPU)
Result: PASS
testweak.tap ......... ok
testtest.tap ......... ok
testpvif.tap ......... ok
testpdb.tap .......... ok
testpvalink.tap ......
not ok 9 - dbGetField("src:i1.VAL", 7) -> 4 == 42
Failed 1/15 subtests
testgroupconfig.tap .. ok
testdbf_copy.tap ..... ok
Test Summary Report
testpvalink.tap (Wstat: 0 Tests: 15 Failed: 1)
Failed test: 9
Files=7, Tests=342, 1 wallclock secs ( 0.19 usr 0.03 sys + 0.00 cusr 0.02 csys = 0.24 CPU)
Result: FAIL
| ANJ, 28 Feb 2021 |
Home
News
About
Talk
Base
Modules
Extensions
